For us 1500 guys, high compression head up on Ebay
RichBall
For anyone that has been looking for the high compression head that came on the Federal spec '76 midget there appears to be one up on Ebay right now. It is a little difficult to make out in the photo, but it looks to have the TKO 2748 head stamping which designates the 9.0 to 1 compression ratio. The Ebay auction number is 330712192406. NFI on my part just thought I'd give a heads up to those looking.
Unless I'm looking at the wrong area I think it says something else.
Here's the zoomed in view of the stampings:
Wrong place Rick.
Look above intake port #3. the number is hand stamped there as each head was machined ar the factory. It's faint, but it looks like it's there to me.
Your're right, it is a 2748. The only difference b/w a 2748 and a 1409 or 1410 is how much it's been milled at the factory. For that much money cut your own.
Not seeing it, I believe you but I just can't see it.
Good Luck reading that. We need some CSI computer power to clear this up.
m
no fraid not. Pretty sure no one else can be certain on that either. i emailed the guy asking what it was....still waiting.
m
m
It's a TKC 2748... :laugh:
C Wanted Spitfire 1500 diff rebuild Triumph Classifieds 0
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 7
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
JPSmit 1500 slave cylinder question Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
Rut 1500 gas pedal for sale Spridgets 7
dklawson Spitfire Spitfire 1500 Block Decking Following Boring ??? Triumph 4
dklawson Spitfire Spitfire 1500 - Front Pulley Nut Removal? Triumph 2
DanLewis Two midgets available: '79 is free [no engine, trans], running '77 $1500 [NFI] Spridgets 1
