Engine build invoice.
tomshobby
I found the invoice for my engine build. It was done a few years before I purchased the car. When I picked up the car and the boxes of parts the engine was sitting on the floor still in the builder's bag. The engine was finished 11/26/02 and had never been started until late Sept 2015. It runs great.
I paid $800 for the car. That included the new carbs, rebuilt engine, the body had considerable work (even though I had to do some of it over), new radiator, and many other new parts.
Still I put a lot of time and money into it.
Engine build invoice dated 11/26/02
Bore job comp 4 cyl .030
Grind crankshaft R.010 M.010
Check connecting rod bores
Resize lg end of rods
Fit wrist pin bushings
Replace connecting rod bushings
Valve job 4 cyl
Resurface 4 cyl cast head .008
Cut & install seats
Install all Guides
Intake valves
Valve cover seal
Disassemble short block
Degrease
Assemble
Misc charges
Engine specs:
Piston clr. .002
Ring side clr. .002
Top ring gap .011-.014
2nd ring gap .011-.013
Oil ring gap .028
Rod oil clr. .0019-.0021
Rod side clr .008-.010
Main oil clr. .0022-.0028
Crankshaft end play .002
Camshaft end play .002
Recommendations:
Start up run eng 1100-1200 RPM for 10 to 15 min to break camshaft in.
Change brake in oil at aprox 100 miles
Change 2nd oil at aprox 500 miles (monitor fluid levels)
3rd oil change at 3,000 miles
Change to synthetic oil at aprox 8,000-10,000 miles.
$1,183.53 total
Wonder what it might cost today.
smaceng
I would guess that did not include parts costs.....even without the parts cost, it was a very good deal. My cost in 2010 was around $1700 for the machine work and the assembly of the short block.
Scott in CA
Bayless
Had my 1275 done in 2000 and total cost, including complete head work was a little over $2000.
dklawson
I spent about $2k on my 1275 10 years ago and I did the re-assembly work, not the machinist. $600 of that was a replacement fully rebuilt head.
By comparison, I just finished rebuilding the 1500 in my son's Spitfire. The machine shop work was very cheap at $430. However, 90% of the engine checked OK so many of the steps on Tom's old invoice were not required (i.e. crank did not need grinding, rods checked OK....) I did have the parts balanced which I did not notice on Tom's invoice. I have another $500 in parts and as before, my labor for reassembly.
Coincidentally, I started the 1500 for the first time this morning. I hate turning the key for the first time on a rebuild. Though I am careful and use checklists, I am always second guessing myself... wondering what I may have forgotten or done wrong.
tomshobby
tomshobby
Yesterday I stopped in to visit the shop that did the work. The machinist was there and we had a chance to talk. He was glad to see that after all this time (12 years) the car was back together and being driven. He said that after he finished the job the guy that had the car waited for quite a while to pick up the engine even though the bill had been paid. He told me that he doubted the owner would ever put it back together.
H MGB Engine build question MG 10
T Selecting octane levell for new engine build[?] Spridgets 7
J TR2/3/3A TR3 engine build Triumph 12
KVH TR4/4A Generator Light Turned on While Out on New Engine Build Drive Triumph 9
G TR4/4A Yet another engine build thread. Parts list: Suggestions/Recommendations/Etc Triumph 11
drooartz MGB Drew's going to build an engine this winter MG 13
richberman Engine build...thanks Superwrench!!! Austin Healey 13
T TR4/4A Randy - how is your TR4 engine build coming along? Triumph 18
L Engine build problems. Desperately need help :,[ Spridgets 34
TR6oldtimer TR5/TR250 TR250 Engine Build Triumph 14
T Wedge Rich - did you finish up your TR8 engine build? Triumph 1
mccalebr Hap's engine build log Spridgets 7
Trevor Jessie First [of many] engine build question Spridgets 3
E TR6 TR6 Engine Re-Build Candidate? Triumph 11
Tinkerman TR2/3/3A How to build an engine run in stand for 60 TR3 Triumph 9
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
