TR5/TR250 TR250 Engine Build
TR6oldtimer
Well this is what I have been up to.
Installation of .030 pistons etc
GP2 cam going in.
Next to degree the cam...
Soon all to be back together, then back to the body work which had become a ordeal.
kodanja
Re: TR6 Engine Build
Looks awesome,
I wish I had the time, money and resources to do mine
poolboy
Nice job on the walls, Ray. What grit ? The rings ought to seat fast. Did you have much of a ridge ?
TR6oldtimer
TR6oldtimer
PB, I had the engine bored, then honed, I do not know what hone the machinist used. And TD, yes, I needed a break from working on the tub, so I moved up the engine build for a break.
Restoration is suppose to be fun, so when parts of it becomes a task, I looked for something else to do that needed doing. Like the rebuild of the starter and soon the alternator. Then I will be back to the tub and put the last rocker panel on, then skin the doors, then do the window frame, then the...
Anyway, variety is the spice of life and it keeps it fun.
tdskip
I totally hear you, and that approach is how I justify having way too many projects. (Doesn't make sense if I look at it rationally but having a justification, even if bogus, makes me feel better!)
TR_JOE250
I can echo that one. Every time I take the cover off my 250 she just begs me for attention and money.
glemon
Nice work, know what you mean, total restoration of my TR250, I feel I need to keep going or it will never get done, I switch around the work too. There are also times I just don't feel like going out to the garage (I have been working on the car pretty much everyday after work lately) if I really don't fee like it I don't go, but many times that just ends up being spending some time on the forum then later in the evening I head on out to the garage.
U joints and front and rear suspension work lately.
Most of the bodywork, though time consuming, I find fairly relaxing. The mechanical work should be too, but so many times the parts don't fit, or something is stuck on or whatever, and the 15 minute job becomes to two hour job.
I have decided I really like buying a running driving car and fixing and improving as needed or desired more than a total restoration. I know others toll differently, but I think I need the reward of driving or at least looking at a nice finished car now and then.
swift6
Thats is how my TR6 recieved the moniker "Josephine". Think of Napoleon's Josephine and you'll see the connection. :crazy:
TR6oldtimer
TR6oldtimer
Shawn, so you caught your car messing around with MG's? :devilgrin:
Anyway, good news, the GP2 cam has been degreed, not as big of a deal as I thought it would be, just of couple of hours of puttering around. A couple of more days, and the engine will be done. Maybe Wednesday...
maybe not.
Brosky
Better Josephine than Evita......
Good looking job so far Ray. Keep the pics and progress reports coming.
TR6oldtimer
TR6oldtimer
Here is a shot of the degree wheel at .010 lift on the intake and the crank at 29 degrees BTDC
Oil pump in
The pan is on, and various other external items, including spin on oil filter. (Yes, after owning a TR4 and this TR6 since '75, I finally popped for the adapter)
The head and valve train is next.
88 degrees here today.
Brosky
Ray,
Did you check the gear clearance in the oil pump? My new pump was within tolerance, but we polished the gears a bit to smooth them out.
A bit anal perhaps, but to me, that pump is the heart of every engine.
TR6oldtimer
TR6oldtimer
Paul, the oil pump was new 16 years or so ago, when the car was laid up. I did check and all three clearances and they were in specification.
Thanks booley, the in block cam bearings were within specification, so I did not have it lined bored for the bearing inserts. Actually, the reason I am building the TR250 block, is that the original TR6 block cam bearings were so far out, they needed to be bored. My problem was finding a machine shop who could do the job. While many had the tooling to line bore a six, they did not have the equipment to bore the case hardened cam bearings. Plus, the crank on the six needed grinding, I figure building out the 250 has saved me $1200.
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
Marvin Gruber TR5/TR250 TR250 Engine differences Triumph 2
glemon TR5/TR250 TR250/6 engine mount Triumph 2
glemon TR5/TR250 TR250 Up-date, engine compartment painted Triumph 16
TR6oldtimer TR5/TR250 TR250 engine numbers Triumph 9
IanF GT6 GT6 engine vs. TR250/6 engine? Triumph 12
glemon TR6 TR250/TR6 Engine Rebuild Question Triumph 7
T TR6 TR250 engine or TR6 ? Triumph 8
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
glemon Wanted TR250 Wheels Triumph Classifieds 1
conan69 TR5/TR250 TR250 seats Triumph 1
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
angelfj1 For Sale TR3, 3A and TR250 Parts for Sale Triumph Classifieds 6
Retired2020 TR250 steering column bushing Triumph 2
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
S TR5/TR250 "New" TR250 on the horizon Triumph 0
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
C TR5/TR250 Tr250 registry Triumph 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
oldbagpipe For Sale '69 TR6/TR250 Seats now available Triumph Classifieds 0
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S For Sale Triumph TR250 Factory Workshop Service Manual on CD/ROM – 1968 Models Triumph Classifieds 0
K TR5/TR250 TR250 question [Not asking for a friend] Triumph 17
T TR5/TR250 TR250 wiper switch and motor Triumph 1
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
glemon General TR TR250 Steering Wheel Options Triumph 6
P Wanted WANTED To Buy a TR4 or TR250 Triumph Classifieds 3
T For Sale TR4 TR250 Rear Fenders Triumph Classifieds 2
T TR4/4A TR4A/TR250 what are they worth Triumph 8
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
M Wanted WANTED TR4A or TR250 fendet Other British Classifieds 0
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
R Wanted TR4A / TR250 Center Console Triumph Classifieds 1
B TR5/TR250 Registry for TR250's? Triumph 1
brgrmyster TR5/TR250 1968 TR250 original emissions lines Triumph 0
RobT For Sale Triumph TR250 - $32K Triumph Classifieds 2
TRopic6 For Sale Flywheel for TR250/'69 TR6 Triumph Classifieds 0
B Wanted TR250 passenger seat Triumph Classifieds 0
