Electrical System
A
aholloway
Well...the restoration continues. Floor pans in bolted and welded. Interior completely gutted which leads to this question. Will the main wiring harness from a 74 tr6 fit a 75 tr6?
Thanks
MDCanaday
Yes the harness will fit but there will be some minor differences. The factory saw fit to change the harness so often that as best I have ever seen there are NO completely accurate diagrams to be found anywhere. Last year a friend of mine nearly went bonkers putting in a replacement harness in a 74.When it was said and done 2 mystery wires of different codes had to be connected together to get the ignition circut to work. These wires didnt show up on any diagram we could find & both had spade recievers on the end. I would say that this is a 2 buddy 3 sixpack kinda project(if you dont drink now , you soon will)
Mark
CARSINC Sprite Electrical System Information Spridgets 2
C Ghost in the electrical system Austin Healey 51
R TR2/3/3A Early TR3 electrical system Triumph 12
6 Electrical System Issue- Thougths Please Spridgets 6
Lbp TR2/3/3A What Might Cause The Entire Electrical System on my TR3A to Die? Triumph 19
coj Electrical system - turn signals - green light Austin Healey 1
Sarastro Not your grandmother's Bugeye electrical system Spridgets 8
kyreb1862 Electrical System Problem Need Help ASAP MG 7
C Electrical system fun! MG 5
T TR6 Fry a TR6 electrical system in these easy steps Triumph 16
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
D TR2/3/3A TR3A electrical issues Triumph 2
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
N Electrical Issues Need Help Austin Healey 8
H Re: electrical short wiring damage Spridgets 11
I Bugeye electrical questions Spridgets 17
N Electrical Troubleshooting Advice Needed Spridgets 6
steveg Electrical sleeving Austin Healey 11
N TR6 Electrical Issues Triumph 5
N Electrical issue. FORUM Navigation Questions 2
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
6inline Electrical gremlins giving me fits Austin Healey 18
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
