Dutch axle windup video
steveg
Am posting this separately to make it easier to find in the future.
Here's a Dutch video of axle activity during a race. Amazing how it all doesn't just break immediately - especially the springs:
healeyblue
I would not have been surprised to see the axle just come loose and fly apart in many pieces. Very impressive to actually see in action. I guess I never thought the rear suspension moved around that much and with such sudden and violent changes from acceleration to deceleration.
BoyRacer
The FIA rules prohibit traction bars on Healeys so the racers across the pond build their rear springs with a very strong main leaf that helps to prevent windup. Even then you can see what happens. The car in the video is driven by Jaap Sinke, the son of Rinus Sinke, a Dutch Healey racer champion.
steveg
steveg
Boy the springs in that video look like noodles.
Patrick67BJ8 Dutch Healey Group On Tour In The US Right Now Austin Healey 9
BigGreen Dutch way to restore a Healey Engine Austin Healey 9
G Dutch Club Healey Pics Austin Healey 1
philman Dutch visitors on a M/C tour Triumph 3
B MGA Axle Brake line MG 0
B MGA Where to Buy, What to Buy? Axle Nut MG 9
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
S TR2/3/3A old 4 bolt axle set up Triumph 12
S TR2/3/3A old 4 bolt axle differential. Triumph 11
KVH General Tech Rear Brakes and Solid Axle Triumph 2
A Wanted Girling Axle for TR2 Triumph Classifieds 5
R BJ7 Rear Axle Maintenance Austin Healey 5
SNClocks Bugeye axle limit straps Spridgets 5
A Rear Axle Oil Seal Austin Healey 4
Lin Bugeye Axle Hub & Bearings Austin Healey 1
P MGB Tube axle wear MG 3
W Rear Axle Hub Seal Austin Healey 8
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
CJD TR2/3/3A Lockheed Axle Triumph 8
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
S Axle Shaft Installation Difficulty - Help Sought Spridgets 8
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
G Trans Axle Parts Lotus 20
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
T Axle spline lengths Spridgets 0
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 17
S Axle leak at backing plate Austin Healey 26
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
D Wanted TR4A Live axle frame Triumph Classifieds 0
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
S Rear axle - small leak .....? Austin Healey 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
S Gearbox and axle serial numbers Austin Healey 7
P MGB Noisy Rear Axle / Differential MG 1
R Rear Axle Restoration Austin Healey 6
Rut TR4/4A 67 TR4a irs to live axle Triumph 18
Lin Rear Axle Hub Nuts Austin Healey 3
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
C Size of axle bearing nut Austin Healey 11
