Axle spline lengths
twas_brillig
Digging around in the attic, looking for differentials (see my power train thread), I found 3 axles, all the same length, and with two of them having splines about 1 7/8" long from the end of the axles, and one that whose splines lengths were more like 2 1/2". Axles all the same length and appearance. Any wisdom as to why that one axle's splines are longer? Thanks, Doug
D Rear Axle Spline Conversion MG 1
G New Axle spline MG 4
B MGA Axle Brake line MG 0
B MGA Where to Buy, What to Buy? Axle Nut MG 9
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
S TR2/3/3A old 4 bolt axle set up Triumph 12
S TR2/3/3A old 4 bolt axle differential. Triumph 11
KVH General Tech Rear Brakes and Solid Axle Triumph 2
A Wanted Girling Axle for TR2 Triumph Classifieds 5
R BJ7 Rear Axle Maintenance Austin Healey 5
SNClocks Bugeye axle limit straps Spridgets 5
A Rear Axle Oil Seal Austin Healey 4
Lin Bugeye Axle Hub & Bearings Austin Healey 1
P MGB Tube axle wear MG 3
W Rear Axle Hub Seal Austin Healey 8
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
CJD TR2/3/3A Lockheed Axle Triumph 8
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
S Axle Shaft Installation Difficulty - Help Sought Spridgets 8
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
G Trans Axle Parts Lotus 20
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 17
S Axle leak at backing plate Austin Healey 26
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
D Wanted TR4A Live axle frame Triumph Classifieds 0
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
S Rear axle - small leak .....? Austin Healey 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
S Gearbox and axle serial numbers Austin Healey 7
P MGB Noisy Rear Axle / Differential MG 1
R Rear Axle Restoration Austin Healey 6
Rut TR4/4A 67 TR4a irs to live axle Triumph 18
Lin Rear Axle Hub Nuts Austin Healey 3
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
C Size of axle bearing nut Austin Healey 11
warwick-steve Oil for rear axle? Austin Healey 3
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
KVH TR4/4A Do I Have an Axle Problem Triumph 11
