DGV throttle linkage help needed
tosoutherncars
Hi all,
I have a DGV to install. The throttle linkage is as found on the exploded diagram below: essentially a C-shaped metal piece.
Exploded view: Weber DGV
Can I use it as-is? Do I need a 'fan' type throttle linkage, as found on the Redline site?
Redline cable install
The B&W photo on the Redline page shows the C-shaped piece *and* a fan-shaped throttle plate. Do I use both?!?
TIA,
Duncan
Cant tell whats going on from that diagram but I had my engine out tonight heres a closeup of my set-up
Some of it is a bit of fabrication but works great
IMG]https://i174.photobucket.com/albums/w111/63midget/IMG_1474.jpg[/IMG]
Yep- that's how I did mine, but I used that wheel throttle linkage that came with my kit. I ran the spring over the cable for a cleaner look and it works fine.
I had to modify my throttle cable by taking about an inch and a half off the sheathing as I could not get enough cable to the throttle linkage.
Don't you have the linkage on the opposite way?
B Weber DGV Throttle Cable MG 2
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
G Webber DGV Jetting FORUM Navigation Questions 5
G Trade Webber DGV Jetting Triumph Classifieds 0
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
Joe Reed MGB A little different DGV installation... MG 12
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
B Weber DGV Spridgets 2
S TR6 dgv's on tr6 again Triumph 24
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
bugedd weber DGV help Spridgets 6
sparkydave Weber DGV running at last! Spridgets 0
sparkydave Weber DGV and 1500 Spridgets 1
C TR6 TR6 with DGV's Triumph 1
M Fuel pump rating for Weber DGV Carb? Spridgets 6
7 Weber 32/36 DGV with intake for sale or trade Triumph 1
7 Weber 32/36 DGV with intake for sale or trade Spridgets 0
X Weber 32/36 DGV fast idle rod MG 0
pjsmetana DGV adjusts and 3 line dipstick - Latest Triumph 7
R k&n air filter p/n for weber dgv on 1500 midget? Spridgets 7
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
tosoutherncars Weber DGV, cont'd... Electric fuel pump install Spridgets 19
M TR2/3/3A TR3 SU's vs DGV's Triumph 9
M TR2/3/3A TR3 DGV linkage Triumph 0
58Custom Seek opinions/experiences w/ Weber 32/36 DGV carb Spridgets 4
M TR2/3/3A TR3 DGV Choke Cable Triumph 2
R weber 32/36 dgv, selecting jets, air correctors? Spridgets 15
R weber 32/36 dgv parts? Spridgets 7
R weber 32/36 dgv carb -- holley equivalent? Spridgets 2
tosoutherncars 1500 DGV - timing Spridgets 12
RickB Weber dgv for my Midget? Spridgets 14
R weber dgv 32/36 installation on 1500 midget? Spridgets 4
R 1500 mg midget, weber dgv carb & affect on timing Spridgets 9
tosoutherncars WEBER DGV - what fuel pump / regulator do you use? Spridgets 8
C MGB Weber DGV setup on 74 MGB MG 13
eejay56 Weber DGV or twin SU HS4s Triumph 12
B Done with this Weber DGV Spridgets 3
Baz DGV pump MG 7
Baz WTB: Intake m'fold for DGV Spridgets 7
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
B Weber DGV troubles... Spridgets 3
J Weber DGV on a Bugeye Spridgets 5
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
tosoutherncars Header & DGV swap underway Spridgets 49
B Do Not give up on the DGV Weber..... MG 12
1976Midget weber DGV Spridgets 10
