TR2/3/3A Crankshaft thrust washers, 60 TR3
Tinkerman
So I got my correct size bearings and the crank fits as it should. I installed some standard thrust washers and found that the end play measured out to .0085. Manual says it should be .004 to .006. I ordered some .005 oversize washers (smallest I could get) if it is to much of a correction is there a way to take some off the washers? Seems I have seen a picture from one of the manuals about sanding with emery cloth. Any experience out there?
Thanks, Tinkerman
You can polish a little off the thrust washers by putting emery paper on a perfectly flat surface (some use glass, but I use a granite 12x12 tile polished smooth). Lightly oil the washer with 3in1 and press lightly as you move the thrustwasher in a figure 8 pattern across the emery paper. Check it with a mic or dial caliper until the desired thickness is reached. Make sure to keep the thrustwasher in 100% contact with the abrasive and double check the thickness in several spots to make sure.
Yes, I have that picture in my TR3 Service Instruction Manual. They can be "rubbed down on emery paper". It looks like the paper is on a flat service, and the mechanic is "rubbing it down" with his fingers. It mentions that "this must be only be carried out on the Steel Side."
You only have .0005" to take off to get to .004" end play, so it shouldn't be too much work.
Thanks to both of you for your comments. I did find the illustration and the comments in the manual.
Cheers, Tinkerman
A bit of advice I would add is when you get your oversize set take one pair and mix with the std. set and measure. You may luck out and not have to grind off anything. The difference in thickness of the steel backing is of no consequence. I'll assume you're using an engine stand for assembly so for initial measurements just do the non-tabbed bearings without bolting up the maincap. Then if you do have to grind, grind on one oversize untabbed bearing and remeasure. Then grind a tabbed oversize bearing to match the untabbed one and then snug up the main cap with all the bearings and measure again. Finally if you do have to grind put the bearings you ground on the FRONT side of the main cap. Reason is no matter how good your measurements appear to be you simply won't be as uniform as a machined part. The front bearings obviously just take up space, but the rear ones have to absorb the load of depressing those nine nasty springs in your clutch (especially heavy duty ones) everytime you push the pedal. So if you were to leave a high spot of say .0001 that spot will get hot and start to melt. I never have understood this design for thrust washers (why they didn't make them just a bit larger) and which is why over the past decade or so I've switched used Vp bearings from the front side (when good) to the backside. They are still superior in that spot.
Tom Lains
TS8651 & 58107
I didn't have a granite plate, but I had heard about using a piece of flat glass. So I went to the local plate glass shop and told him that I wanted a piece about 10" square and about 3/4" thick. He had a scrap piece in a rubbish bin somewhere and trimmed it to size for me. The cost ? FREE ! That was nice of him.
Thanks to all of you for your thoughts. I got the 5 thousands oversize today, put one set in and my DTI now reads .0045 which, as far as I'm concerned, is perfect. Yea!
Cheers, Tinkerman
P TR2/3/3A Crankshaft Thrust Washers Triumph 4
J TR2/3/3A Crankshaft thrust washers. Triumph 2
H Crankshaft Thrust Washers Austin Healey 2
M Healey Crankshaft Thrust Washer Thickness Austin Healey 3
mctriumph TR4/4A Busted crankshaft Triumph 20
Michael Oritt Looking for a good 100 crankshaft Austin Healey 5
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
B TR6 Crankshaft long seal surface Triumph 5
MKIII_Joey Crankshaft Bearing Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
B General MG Crankshaft Nut Removal MG 4
KVH General Tech Dog Bolt Torque—Crankshaft Triumph 11
W Crankshaft Oil Seal Austin Healey 3
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
B MGB Mgb crankshaft end play shims MG 2
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
T crankshaft (rear) bearing leak Spridgets 2
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
R Wanted 3 main crankshaft MG Classifieds 0
glemon TR2/3/3A Crankshaft Question Triumph 3
J Crankshaft Dog Nut and Timing Chain Cover Removal Austin Healey 39
AUSMHLY Crankshaft Starter Nut Austin Healey 10
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
M TR2/3/3A Crankshaft Pulley Configurations Triumph 3
M TR2/3/3A Crankshaft Oil Galley Plugs Triumph 7
S TR4/4A Fair price for a crankshaft? Triumph 2
charleyf TR2/3/3A crankshaft hardening Triumph 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
G Crankshaft Rotational Freeplay - What's going on with this engine? Austin Healey 12
O Wanted TR 3 Crankshaft please... Triumph Classifieds 1
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
C Tough Bolt on front of Crankshaft Spridgets 16
TRMark TR4/4A Prepping Crankshaft Triumph 4
D TR2/3/3A crankshaft shims to align timing sprovkets Triumph 4
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
tinman58 TR5/TR250 Front crankshaft seal Triumph 0
2billydavies TR2/3/3A removing con rod from crankshaft Triumph 4
C Crankshaft pulley / damper Austin Healey 5
HJR TR2/3/3A Crankshaft crank bolt head[108498] Triumph 10
M For 1974 MG Midget - Crankshaft pulley bolt is 1 5/16"? Spridgets 4
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
M_Pied_Lourd TR2/3/3A TR3A Crankshaft Question Triumph 3
B crankshaft/cam timing Austin Healey 10
RedTR3 TR2/3/3A TR3 Crankshaft Options Triumph 10
