Clearcoat overspray in engine compartment
tr8Fan
I had to paint the front of my TR8 and thought that I had the engine compartment well covered. However, after pulling the paper off, there was clearcoat overspray all over. I'm looking for suggestions as to how I can remove the overspray from this area? There are to many corners in this area for a buffer. Also, just to let you know, the engine is removed.
Thanks
Dude this is not good, you will likely have to re-spray the bay to put it right. The modern clear coats are SUPER aggressive and will stick to any surface they find. In our shop (like most) we bag off each vehicle in plastic and use foam tape to seal off all openings. It is probably not practical to polish (as you said)and it cant be disolved, so sanding and more clear coat will be the best out now.
Be sure not to compound the problem, mask the outside VERY carefully.
MD(mad dog)
JodyFKerr Windscreen aluminum - clearcoat or not? Spridgets 11
jaybird Car-related -- clearcoat or not...just the facts Restoration & Tools 0
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Hangtown Healey overspray removal on vinyl Austin Healey 5
eschneider paint overspray on leather Restoration & Tools 7
J SafelyRemoving Paint Overspray from radiator fins? Austin Healey 8
KLUTZ Overspray on inside panels Restoration & Tools 1
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 0
R TR2/3/3A Engine revs up and down Triumph 7
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 22
L General Tech Engine id Triumph 9
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
