BJ7 Front Brake disc hitting
RestoreThemAll
Good day folks. I'm working on what my son calls "the car that would not be restored", '63 AH BJ7. We’re just coming back to the front brakes and hubs. The only new part on the front brakes, other than the caliper rebuild, is the disk. The rest of the parts related to the below problem are all original.
Unfortunately, the inside edge of the disc scrubs on the caliper mount. There is a small bump out just under the bottom rear caliper mount bolt. It hits there. The disc also hits on the outside of the edge of the disc. There is a small bump out on the dust plate.
I included pics of the original disc and the new one. It’s clear that they have been machined and molded differently. I should also note that I read a post about BJ7 and BJ8 disc being slightly different. BJ8 ½” thick and BJ7 3/8’ thick. Both of mine, new and old, are 3/8” thick. Has anyone come across this problem? Can the inside edge of the disc be shaved at a brake shop?
As for the dust plate, it does seem to have a little bit of a curve to it. Just slight. Are they perfectly flat? That may be why it hits? I hope that it didn’t get warped from glass beading. Can the outside edge of the disc be shaved at the brake shop?
Thoughts?
You say that it's "clear that they have been machined and molded differently". Sounds to me like you have a defective product.
Richard, I'm thinking that you are right about the defective part. There's groove that is cut around only about 1/2 way. It can be seen in the pic. I'll have to pull the receipts. Seems like the disc came from Moss. Maybe they'll work with me, though I've had them for a while.
Steve, I'll check the dust shield tonight. I didn't think to check for orientation. I was thinking that they went on one way only.
Dale
Lay the rotors flat and next to each other, and take a photo. If the angle of the center hub mount of the new casting is more vertical than your original, you may have a BJ8 rotor.
Bob, thanks for the tip. After studying pic/diagrams on the Moss and AH Spares web sites I did notice that difference in the discs, though I didn't mention it. I'm fairly confident that I have BJ7 discs.
Dale
Dale, I too had this same problem on the BJ7 I'm restoring (parts were from Moss). Fortunately it was only a very slight interference between the rotor and the stationary part, so I took a "peanut grinder" and relieved the offending area. BTW I think you have your backing plates on correctly. Griz
When I mount the brake caliper it may change the way the sheild sits. I'll have to get past the problem with the inside of the disc first.
I had both front brake rotors shaved on the inboard inner edge. The left side is perfect now. The right side doesn't hit at all on the inner edge but does hit some on the shield. It's not hitting much. Just a very slight scrape every so often. The only part that's troubling is that it doesn't hit all the way around the rotor. Once every revolution. I'll have to set up something to try and see if the rotor is warped. I'd simply order another rotor but I'd be concerned about getting more defective parts. The vendor says that they aren't having any problems with their rotors. Though we know that isn't the case.
If there's a problem with the discs such that you had to shave them down, Moss needs needs to know about it. I've found them to be very responsive to quality-related issues.
Your rotors should be approximately 3/8" thick; late BJ8 rotors will be 1/2" thick.
I also have problems with new brake discs from MOSS
REQUEST re Rectification -
Could you please confirm that you just had to grind down the inner edge of the new disc to avoid the interference with the caliper bracket.
I purchased a large number of parts at the start of the project through a local MOSS distributer, and I have now passed the MOSS return date. So i am hoping that i can fix the problem by grinding the discs to make clearance.
Many thanks for you help
Regards
Brian
Brian,
Yes, we ground the inside edges of the new discs. I'd suggest taking off material evenly all the way around. You don't want it out of balance.
Dale
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
R Help with BJ7 front brake line routing Austin Healey 6
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
B Front Seat Bases and Door Seals -- BJ7 -- Advice Austin Healey 6
maxwedge5281 front pieces for bj7 hubs with bolt on wheels Austin Healey 8
R BJ7 front hub shim question Austin Healey 18
B Fitting grille surround to front shroud - BJ7 - any advice? Austin Healey 21
B Removal of front fender on BJ7 Austin Healey 14
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D BJ7 Hood frame mounting plate Austin Healey 7
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
