MGB Biggest 15 inch tire for 80 MGB
R6MGS
I should be getting an 80 MGB for winter use and I have a set of old custom mags from an MGA that should fit(right??) that are 15 inch(I figure the bigger wheels won't hurt in the snow). I wanna get some big meaty snow tires for them but I need to know what is the largest 15 inch tire that will fit on a stock 80 MGB without rubbing?? Anyone running anything big like that?
Thanks
billspohn
You don't say what width or offset the mags are. Generally speaking a 185x60 is probably the largest, but you may get rubbing at the rear of an MGB.
BTW, you often get better traction in the snow with narrow tires, than with wide ones.
R6MGS
R6MGS
I don't know the offset or width offhand....The rims are burried under alot of junk. And I realize narrower is usually better in snow,but I don't want like pizza cutters....a 185 is still pretty dang narrow and thats about what I was thinking would work best as well.
Steve_S
I have 195/60R15 on 5.5" rims fit to a '65 B, but the alignment of early Bs is typically better than later ones. Plus I have poly bushings and heavy duty wire wheels.I've heard of cars with 205/60 fit but I believe they have gone to extra lengths to center the rear axle precisely.
R6MGS
R6MGS
Ok, thanks....I guess once I get the car(assuming the owner gets her ownership issues sorted out so that I can actually buy it :S) I'll try the rims with the old tires that are on there and see how much room I've got...Would it be tighter in the rear or up front??
billspohn
The problem is the rear fender lips.
PAUL161
Saw a "B" at the last show that had 185/65-14s on it with after market wheels and it had plenty of clearance in the wells and looked very nice. Notice I said 14s not 15s.
WA1KWA
When my B was an autocross beater I ran 195/60 x 14 on the Rostyles.
They JUST cleared the wheel opening lip.
Colin
billspohn
I run 185 x 70 - 15s on my MGC on 5.5" wires, but I'd repeat that you will have better traction (which I would have thought would be your primary concern, over appearance) with a 165 x 70-15 or an equivalent 14" size.
R6MGS
R6MGS
Thanks for the input guys....I am waiting until I pick up the car on Sunday to decide for sure, but I am pretty sure the tires on it were new-ish So I may just leave it alone and go with that....Depending on how it performs in the snow I'll look into putting on these mags and some snow tires. I doubt the mags could handle too wide of a tire anyway given that they were supposedly custom made for an MGA, so they're probably pretty narrow rims.
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
mylillooker The Biggest Battery in the WORLD Spridgets 4
M biggest forum MG 6
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage MG Classifieds 1
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage Austin Healey Classifieds 1
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
TomMull For Sale 10 inch Mini Rims (2) Other British Classifieds 1
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
5 Sumitomo 13 inch Tires Spridgets 19
DornTRoriginal For Sale 9 Inch Brake shoes from TRF Triumph Classifieds 5
Marla TR4/4A Can someone please give me another inch or two? Triumph 1
Martinld123 Want to lower car about an inch Austin Healey 4
roysimpsonjr TR4/4A Will an 8 inch wide radio fit? Triumph 3
C A great substitute for a "Not Quite 3/4 Inch" hex wrench Austin Healey 9
maxwedge5281 1/2 inch wheel studs Austin Healey 8
CJD TR2/3/3A 9 VS 10 Inch Rear Brakes Triumph 15
maxwedge5281 drivers side 4 inch vent hose Austin Healey 5
H Spitfire Spitfire MK IV - tyres on 14 inch wheels Triumph 0
E With frame on level stands my drivers front fender is 1 inch higher than the pass? Austin Healey 5
R TR4/4A Tire options tr4a 60 spoke wheels 4.5 inch wide Triumph 43
5 one inch rear wheel cylinder Austin Healey 1
mgedit TR2/3/3A Alloys on TR3 with 10 inch drums Triumph 5
M Tips for paint touchup on 1-2 sq inch areas? Spridgets 3
64Elan 14 inch wheels Triumph 11
T 6 inch wide wire wheel Austin Healey 3
hondo402000 14 inch painted wire wheel any one need it Triumph 1
PATR8 Bought 15 inch rims for my 8 Triumph 3
PATR8 Wedge 15 inch rims for the TR8s Triumph 15
J Six inch rims on a Mk2? Jaguar 3
angelfj1 13-inch American Racing Wheels on eBay Racing 0
AltaKnight What a difference an inch makes.... Triumph 5
Jayrz 14 Inch Wheels Spridgets 25
G 6 & 7 inch wheels Triumph 2
beaulieu any skinny 16 inch radial tires 5.00x 16 or so ? Restoration & Tools 4
drooartz Spridget gauges, which are 4 inch? Spridgets 9
T TR2/3/3A Four inch wider TR3 photos available! Triumph 17
S TR2/3/3A tr3 - 9 inch rear brakes Triumph 1
milemarker60 TR6 8 Inch Wide Wheels on a TR6??? Triumph 2
C TR2/3/3A TR3A 10 inch rear brakes Triumph 7
M Oil Pan Gasket - 4 inch pieces? Austin Healey 2
bighly 3/4 inch sway bar bushing interchangability MG 2
S TR2/3/3A tr3 -- 7/8 or 1 inch slave cylinders Triumph 3
S TR2/3/3A Tire balance Triumph 15
J MGB Tire pressure for 1980 MGB MG 14
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Tire Age Austin Healey 14
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
Frameman 1949 Tire Options Austin Healey 16
T TR6 TR6 Tire Pressures Triumph 2
