TR2/3/3A Four inch wider TR3 photos available!
TR3Mod
Hi folks
Finally got around to posting some photos of 'The project'. if you'd like to see what I'm up to you can go to www.photobucket.com. Find me by entering TR3Mod in the search field. My photos should come up. To enlarge the image just click onto the thumbnail. I've included a title with each photo to direct you to the main idea in each picture. I'd like to get your feedback and answer any questions you guys might have. The project is going very smoothly, and I'm having way too much fun with this.
Cheers, and have a great Christmas. Just remember Joseph Lucas's last words.... 'Never drive at night!'
TR3Mod
jsneddon
Holy Sawzall Batman!
that's pretty sweet. That's gonna be a WIDE tranny tunnel - you could cook a turkey under there!
I like it!
I'm such a moron - I'm thinking "Where the heck did those trailing arms come from"....
duh... TR6...
So what are you going to do with the dash? You could split it and build a bigger center console with 4 more guages! Or install a DVD screen!
4 inches doesn't sound like much but jeez... that is going to be pretty cool!
T
TR3Mod
Hey,
Transmission cover will be stock- the floor pan grows inwards, 2 inches added to each one. Your comment about where the trailing arms came from is just what I want to hear. This thing is supposed to provide exactly that reaction.
vrod
makes me want to build one too. How similar to the tr6 is the tr3 wheelbase? congratulations! Your living many of our dreams.
G
Fits on a TR6 chassis - hmm, when are you coming out with the kit?
/ubbthreads/images/graemlins/laugh.gif
martx-5
That's great. If you run aeroscreens, then you won't have to figure out what to do about widening the windsheild. Of course, that might not be too much of a problem on the 3, as the windsheild is flat.
We're doing a similar mod at the Long Island Triumph Association . (Click on TR6 + 6) We're widening a TR6 by six inches. One big concern, is of course the windsheild. One other problem was widening the rack and pinion. We basically cut it in half and welded additional sections in. After the body was off, we found that the original frame was just too far gone to widen, so we built a new one. That's when the owner of the car and the shop we are using got the idea to build new frames for TR's. You've probably seen them advertised. Anyway, because of that, the TR6+6 got put on hold for awhile.
Are you going to relocate the steering and pedals now that the cockpit is wider?? Since we went 3 inches wider on each side, moving those items only makes sense in order to take advantqage of the extra width. Also, is there room for the six cylinder engine?? That would be cool. Actually, there be plenty of room for a small Ford V8.
Keep us posted on the progress, and the pitfalls you run into. The more I think about this, the better I like it. It's a much more sensible project then widening a TR6. /ubbthreads/images/graemlins/cheers.gif
Bruce Bowker
The reason for doing this is to fit a TR6 chassis?
A lot of work but sure looks like you are doing a super job of it.
Bruce
Bruce Bowker
[ QUOTE ]
[/ QUOTE ]
Not being at all facetious here - why?
Bruce
Andrew Mace
[ QUOTE ]
[/ QUOTE ] Ahh...point of fact: the TR2/3 windshield is NOT flat. It has a bit of a "convex" bow in it, added early on in the development of the TR2 prototypes.
martx-5
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
Bruce
[/ QUOTE ]
The owner of the car just felt that the TR6 should be wider. He's also putting in the aluminium V8 Rover engine. Besides it's become a Saturday project for the club members. Other then that, there is no good reason to do this. As I mentioned earlier, widening the TR3 makes much more sense, as there is an available chassis to drop it on that doesn't need big modifications. There will be some problems with widening the TR3, but they only involve the body, and not the whole car. To me, the end result of the TR3 widening will yeild a much improved car that will be very subtle in what was done as opposed the the TR6+6 project./ubbthreads/images/graemlins/thirsty.gif
Edit: By the way, will this be a wide narrow mouth, or a wide wide mouth??
swift6
[ QUOTE ]
[/ QUOTE ]
TR2's thru TR6's all have an 88" wheelbase, 7's and 8's have an 85" wheel base. The main difference dimension wise between the body on frame TR's is their "track width" which is why widening the TR3 body will allow it to fit onto the TR6 chassis.
The body on Frame TR's are an interesting implementation of automotive evolution.
T
TR3Mod
Front cowling is a small mouth and will have 1 inch added on either side and 2 inches right up the middle. I'm hoping this will keep the basic proportions.
Mickey Richaud
[ QUOTE ]
[/ QUOTE ]
Or, maybe "intelligent design"?
(Sorry, don't want to start anything - just couldn't resist!)
/ubbthreads/images/graemlins/jester.gif Mickey
T
TR3Mod
You are correct- TR3 windshield is not flat. I will be running widened 'Brooklin' wind screens, but also want to be able to put my widened soft-top up in rainy weather. I've started doing an informal 'survey' of likely windshields that may work. I know that a windshield can be cut down, so it's a matter of finding the right curve that is also wide enough. I may haver found it. Toyota Landcruiser BJ70 or 71 series. Who'd have thunk it?
TR3Mod
martx-5
Being that the TR3 windshield ISN'T flat as has been pointed out, then there is more of a problem in trying to fit a windscreen to the wider body. On the TR6+6 project, several windshield options were looked at. One was of course to find an appropriate piece of glass from another vehicle that would work. That could be like finding a needle in a haystack. Option two was to have one made to spec. That can be done, but the cost is pretty high. I believe we were quoted about $2500 for the TR6+6. Option number three is probably the one we'll go with. It involves the cutting of two windshields and having them joined in the middle. The guy who does this said that the seam will have some distortion at the join, but it won't stick out like a sore thumb. I told the guys when we were discussing the windscreen, that aero screens were the easiest way to proceed, but I got shot down. Jeez, before I started the resto, I drove the TR3 all over with just the aeros on. /ubbthreads/images/graemlins/driving.gif
swift6
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
/ubbthreads/images/graemlins/nonono.gif /ubbthreads/images/graemlins/lol.gif How very current event of you Mickey! /ubbthreads/images/graemlins/rolleyes.gif
No worries... /ubbthreads/images/graemlins/cheers.gif
CARSINC For Sale Four Octagonal Knockoffs Spridgets Classified 0
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
JPSmit Question four - headlight trim ring Spridgets 9
T Morgan Plus Four Presssure Plate Other British Cars 1
J Can A BJ7 Two Light Schroud Be Coverted To A Four Light BJ8 Style? Austin Healey 6
5 Looking for four original sprite rims Spridgets 10
Tinkerman TR2/3/3A TR3A 1960 Gas on three out of four plugs ? Triumph 6
PATR8 Wedge TR8 four barrel intake mounted reverse Triumph 10
tinman58 back on all four Triumph 1
D Bn1 four speed? Austin Healey 2
aeronca65t Four Wide finish. Racing 3
aeronca65t Four Lotus Cars Lotus 6
PC four wings Spotted 1
Sarastro Four RWA Midgets on LA-Area Craigslists Spridgets 4
J TR4/4A TR4A - Four letter word Triumph 20
B TR2/3/3A 1957 TR3/ Minor detail questions Part FOUR Triumph 6
regularman LA Seven Mary Three and Four Spridgets 1
Morris Tube shocks on all four corners! Spridgets 13
drooartz Four years ago today... Spridgets 7
T Drew - the Bugeye is back on four wheels Spridgets 14
R Holly cow there were four!! TVR 3
Trevor Jessie Small four post lift Spridgets 9
drooartz Progress: four wheels on again! Spridgets 6
rick_ingram Four Link install complete MG 0
rick_ingram Classic Conversions Four Link Rear Susp Installed MG 2
Dave Russell Adding PCV valve to four cylinder Austin Healey 3
rick_ingram Classic Conversions Four Link MG 4
JPSmit one step forward four @#$%* steps back Spridgets 16
A Austin Ten Four Chrom Rad Wiring Other British Cars 13
2wrench Head gasket with four holes Triumph 3
jmwuva05 I need a four way brake union bad!!! Spridgets 4
Bruce_B New oil pump with 2 screws - old one had FOUR!!? Spridgets 3
C Toyots Four Pot Brakes Pictures Triumph 12
D Wedge TR7 four cylinder Triumph 2
jlaird Only four more members Spridgets 13
Team_Sprite He stood on his own four feet tonight! Spridgets 2
aeronca65t Ariel Square Four British Motorbikes 10
DrEntropy It only took me four years! Other Cars 23
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
TomMull For Sale 10 inch Mini Rims (2) Other British Classifieds 1
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
5 Sumitomo 13 inch Tires Spridgets 19
DornTRoriginal For Sale 9 Inch Brake shoes from TRF Triumph Classifieds 5
Marla TR4/4A Can someone please give me another inch or two? Triumph 1
Martinld123 Want to lower car about an inch Austin Healey 4
roysimpsonjr TR4/4A Will an 8 inch wide radio fit? Triumph 3
C A great substitute for a "Not Quite 3/4 Inch" hex wrench Austin Healey 9
maxwedge5281 1/2 inch wheel studs Austin Healey 8
CJD TR2/3/3A 9 VS 10 Inch Rear Brakes Triumph 15
