Want to lower car about an inch
Martinld123
Bronze
I would like to lower my 1956 BN2 about an inch so tires fit wheel arch better but worry my wider than stock tires might hit side of wing on rough roads. My tires are Continental, ContiProContact, 195/65 R15 91H which look good and stick like glue. My front right tire opening is 3.25" while other three are at 2.75". Would I be taking a chance to drop right to 2.25" and other three to 1.34"? If it would be okay what is best method? I think I would put a one inch block spacer under front shocks?? Not sure on tires back arch. Thanks Marty
John Turney
I also have 195/65 R15 tires. I lowered the front about 3/4" by putting spacers between the front spring pans and the lower A-arms. Looked good and didn't hit the fenders, but did keep hitting the oil pan. I reduced the thickness of the spacers to raise the car about 3/8". The oil pan appreciated it.
Michael Oritt
Martin--
You may find it cheaper in the long run to get a tire that fits so you don't have to lower the car to make it "look" correct and risk ripping off your sump in the process. I believe the diameter of your tire is about 25" whereas the Michelin XAS's I use are almost 2" greater in diameter and fit perfectly.
Looks are in the eye of the beholder said the man as he kissed the cow, but I don't believe Healeys, much less 100's, are graced by lowering or by small diameter/low aspect tires.
Martinld123
Martinld123
Bronze
Martin--
Thanks. My tires are 24.5 inches so two more inches would be what I want. Tires only have a few thousand miles but maybe next year I will look into getting ones that fit better. I like the wide stance but larger diameter would be the answer. These tires cost me $500 installed so might be worth it if the other set cost about the same. Thanks Marty
Martinld123
Martinld123
Bronze
Martin--
My tires specifications state my diameter is 24.98". Then looked up your tire diameter and it is 25.42". Less than half inch difference might not be the answer I am looking for. Am I reading the specifications wrong? When these cars are restored one or more times these dimensions might change. Thanks Marty
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
S TR2/3/3A lower small brass bushing Triumph 13
S TR2/3/3A steel bushings for the lower Arms Triumph 10
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
R TR6 Lower A-arm trunnion bushings Triumph 18
edkap2002 TR6 lower radiator hose fitting Triumph 2
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
B TR2/3/3A lower wishbone installation Triumph 5
L TR2/3/3A Bent lower wishbone arms Triumph 6
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
KVH General TR Pressing in the Lower Control Arm Bushing Triumph 6
C TR6 Lower A-arms Triumph 8
wangdango BJ8 lower radiator hose! Austin Healey 2
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
Rut TR4/4A Lower fulcrum brackets Triumph 3
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
Tr3aguy TR2/3/3A Lower control arm question Triumph 2
aero3113 100 lower windshield seal Austin Healey 4
RCarr BN1 Lower Control Arms Austin Healey 0
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
Jeepster Lower wishbone bush replacement. Austin Healey 33
H Post-War Other Herald rear suspension lower block installation Triumph 3
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
Rut TR4/4A Lower crash pad Triumph 9
KVH General TR Lower Control Arms Triumph 1
BoyRacer BN1 lower control arms Austin Healey 1
B TR2/3/3A Removing front lower wishbone confusion Triumph 3
M TR4/4A Left lower dash crash pad. Triumph 5
Geo Hahn TR2/3/3A lower generator bolt Triumph 7
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
M TR4/4A Lower crash pads for dash....help. Triumph 4
sqbsprite TR6 Frame cracking around lower control arm mount, have you checked yours? Triumph 3
Keith_M Lower wishbone recondition? Spridgets 5
PAUL161 T-Series Windshield lower rubber MG 5
J TR2/3/3A Lower windshield rubber seal Triumph 3
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
madhouse RF Fender and Lower Cowel Body Parts needed Austin Healey 10
J Poly Lower A-Arm Bushings - One easy question as I am confused Austin Healey 1
CJD TR2/3/3A Lower Inner Wishbone Bushings Triumph 2
gubba TR4/4A Lower Trunnion question Triumph 8
W Etype lower ball joint removal Jaguar 14
R TR2/3/3A Windshield lower seal orientation, again... Triumph 9
