14 inch wheels
64Elan
Okay, as long as I'm posting on the Triumph area I might as well ask this question.
My Elan has the same bolt pattern as your Triumphs for the most part. Are 14 inch wheels available in 3 3/4 in bc that I'm not aware of? As you all know the 14 inch wheels will give me more tire options.
DNK
If you Go 15's and can handle a 205 x 50 as the TR7's do I would go that way.
Not a lot of 14" choices like the 13's
64Elan
64Elan
Thank, but I think 15 inch would be way too big and 205's too wide. Minilite does make a 14 inch in 5.5 and 6 inch wide but not sure if they offer it for the Elan. You're right though, even 14 tires are getting harder to find.
TR3driver
Great Pumpkin - R.I.P
You might want to investigate a bit closer; the low profile can more than make up for 2" of rim diameter, and you don't have to go as wide as 205 if you don't have room.
I bought new 14" wheels for my Stag, and I'm sorry I didn't get 15s instead.
DNK
Mr. Elan. Shame on Doc for not mentioning this in the Lotus Forum,and I know he stops by there for a few CABs quite often. One of our sponsors sells just what you want. You might want to check them out.
swift6
The 4x3.75 bolt pattern that Lotus used is shared with the Herald, Spitfire, GT6, Vitesse, TR7/8 and a few other Triumph models that were not imported in any great number over here. Like your Lotus, they all used 13 inch wheels.
Like Don posted, there isn't a whole lot more tire choice in 14" sizes. The wheel choice for that bolt pattern is very small as well. I recently resorted to using an adapter and changed my bolt pattern. Problem solved for me.
Platinum
The Elan will have problems with clearance both on the outer upper fender lip and inner well up front, the rear outer lip, with anything wider/larger diameter than the 13" rims and a 185/70 tire. +2 wheels could be used (they are 1/2" wider) but the front clearances (or lack of) are still an issue . Check out Tire Rack, call 'em to see what they have in 13" offerings at the moment. Coker may have some choices as well...
...unless you want to flare and bulge the wheel wells. :shocked:
To accomodate a bigger contact patch really requires a LOT of redesign of the standard Elan bodywork and geometry. It's a slippery slope. And gets REALLY expensive very quickly.
swift6
I realize that my TR8 has more room than an Elan to do plus sizing but I just recently made a +3 sizing change and the rolling diameter of the new 16" wheels is only .31% different than the original 185/70 rolling diameter. So the diameter can be made a non-issue if the right tire choices are available. The extra width that may be necessary simply from limited choices in tires could be another issue.
Platinum
On that beast it really is, Shawn. You can barely get a pencil between lip and rubber as it is with a 185/70-13. Wider at the same diameter would remove chunks of coachwork on a full-lock turn if you ran over a pea... :shocked: :jester:
64Elan
64Elan
Thanks for all the response. I'll stick with what I have and 175/70-13 tires. As you go up in size then the tires and wheels all get heavier etc. My fenders are flared slightly which at some point will get taken back to stock so I'm hoping that somone steps up and starts making 13 inch tire again that will fit Elans and Spidgits, and Triumph's, etc with some sticky compounds. Sorry for posting here, but I had the gas cap issue I needed to identify, and I knew Triumph shared the same bolt pattern so I thought this was a good place to start.
DNK
Just don't let it happen again :jester:
Great to have you,and Doc gets giddy when a Loti question pops up.
Platinum
This IS a good place to start. :laugh:
And YES, DOn... I'm AbsLUtEly ChuFfeD when a Lotus issue is raised. :jester:
64Elan... what gas cap issue? If you look at Norton bikes of the era you'll see the same cap. Morgans used 'em too.
H Spitfire Spitfire MK IV - tyres on 14 inch wheels Triumph 0
R TR4/4A Tire options tr4a 60 spoke wheels 4.5 inch wide Triumph 43
angelfj1 13-inch American Racing Wheels on eBay Racing 0
Jayrz 14 Inch Wheels Spridgets 25
G 6 & 7 inch wheels Triumph 2
milemarker60 TR6 8 Inch Wide Wheels on a TR6??? Triumph 2
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
TomMull For Sale 10 inch Mini Rims (2) Other British Classifieds 1
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
5 Sumitomo 13 inch Tires Spridgets 19
DornTRoriginal For Sale 9 Inch Brake shoes from TRF Triumph Classifieds 5
Marla TR4/4A Can someone please give me another inch or two? Triumph 1
Martinld123 Want to lower car about an inch Austin Healey 4
roysimpsonjr TR4/4A Will an 8 inch wide radio fit? Triumph 3
C A great substitute for a "Not Quite 3/4 Inch" hex wrench Austin Healey 9
maxwedge5281 1/2 inch wheel studs Austin Healey 8
CJD TR2/3/3A 9 VS 10 Inch Rear Brakes Triumph 15
maxwedge5281 drivers side 4 inch vent hose Austin Healey 5
E With frame on level stands my drivers front fender is 1 inch higher than the pass? Austin Healey 5
5 one inch rear wheel cylinder Austin Healey 1
mgedit TR2/3/3A Alloys on TR3 with 10 inch drums Triumph 5
M Tips for paint touchup on 1-2 sq inch areas? Spridgets 3
T 6 inch wide wire wheel Austin Healey 3
hondo402000 14 inch painted wire wheel any one need it Triumph 1
PATR8 Bought 15 inch rims for my 8 Triumph 3
PATR8 Wedge 15 inch rims for the TR8s Triumph 15
J Six inch rims on a Mk2? Jaguar 3
R6MGS MGB Biggest 15 inch tire for 80 MGB MG 9
AltaKnight What a difference an inch makes.... Triumph 5
beaulieu any skinny 16 inch radial tires 5.00x 16 or so ? Restoration & Tools 4
drooartz Spridget gauges, which are 4 inch? Spridgets 9
T TR2/3/3A Four inch wider TR3 photos available! Triumph 17
S TR2/3/3A tr3 - 9 inch rear brakes Triumph 1
C TR2/3/3A TR3A 10 inch rear brakes Triumph 7
M Oil Pan Gasket - 4 inch pieces? Austin Healey 2
bighly 3/4 inch sway bar bushing interchangability MG 2
S TR2/3/3A tr3 -- 7/8 or 1 inch slave cylinders Triumph 3
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M For Sale Vintage Modular HTN 3 Piece Racing Wheels 13" Triumph Classifieds 0
B Wheels and Tires Selection Austin Healey 10
F MGB-GT what do these wheels go to MG 1
CARSINC My Spyder-Mite Gets Wheels Spridgets 9
K TR2/3/3A American Racing Slot Wheels Triumph 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
T "Flashpower" Steering Wheels Austin Healey 3
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
