6 & 7 inch wheels
Gordo
I don't want to step on Brosky's thread about wheel choice. I know what I'd like, but not how to get there.
I'm starting to shop for wheels for my 6. I have made my mind up on Panasports. What I'm debating is the wheel width and diameter.
I'm considering a 6 X 15 inch wheel for the front and a 7 X 15 inch for the rear.
I have lever shocks and have no intention of converting at this time so I think the 7 will fit on the rear.
Has anyone done something like this? If so, what size tires did you use to maintain an even look from front to rear? I tried Tire Rack but couldn't answer my question.
Any suggestions or problems with this setup?
Gordo
edit: I should mention my cars a 6
PeterK
Re: 6 & 7 inch wheels
While you're looking, why not consider +1 sizing and go to 16" rims? A few people have done this on a 6 with 7" rears.
Tosh
I have 7" Konigs on the rear of my '6'; stock suspension; no problem.
I have 7" Konigs on the front of my '6'; reversed upper 'A' arm pivots; problem.
I have modified the upper ball joints to deal with a rim to upper ball joint interference condition on turn in. I have documented this with photos but haven't been able to drive the car (to test). I cannot back the car out of my garage because of construction in front of that bay. I will report on this as soon as I am able.
The wider wheels and the 205/70R-15 tires and the negative camber provide very solid handling compared to the stock wheel/tire configuration.
I do not know whether non reversed 'A' arm pivots cause the same interference on 7" wheels.
As I mentioned in a post a few weeks ago. I would be greatly tempted to go with 16"x7" wheels to avoid potential rim to ball joint contact. They were not available at the time of my purchase.
Hope this helps. Keep on.
H Spitfire Spitfire MK IV - tyres on 14 inch wheels Triumph 0
R TR4/4A Tire options tr4a 60 spoke wheels 4.5 inch wide Triumph 43
64Elan 14 inch wheels Triumph 11
angelfj1 13-inch American Racing Wheels on eBay Racing 0
Jayrz 14 Inch Wheels Spridgets 25
milemarker60 TR6 8 Inch Wide Wheels on a TR6??? Triumph 2
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
TomMull For Sale 10 inch Mini Rims (2) Other British Classifieds 1
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
5 Sumitomo 13 inch Tires Spridgets 19
DornTRoriginal For Sale 9 Inch Brake shoes from TRF Triumph Classifieds 5
Marla TR4/4A Can someone please give me another inch or two? Triumph 1
Martinld123 Want to lower car about an inch Austin Healey 4
roysimpsonjr TR4/4A Will an 8 inch wide radio fit? Triumph 3
C A great substitute for a "Not Quite 3/4 Inch" hex wrench Austin Healey 9
maxwedge5281 1/2 inch wheel studs Austin Healey 8
CJD TR2/3/3A 9 VS 10 Inch Rear Brakes Triumph 15
maxwedge5281 drivers side 4 inch vent hose Austin Healey 5
E With frame on level stands my drivers front fender is 1 inch higher than the pass? Austin Healey 5
5 one inch rear wheel cylinder Austin Healey 1
mgedit TR2/3/3A Alloys on TR3 with 10 inch drums Triumph 5
M Tips for paint touchup on 1-2 sq inch areas? Spridgets 3
T 6 inch wide wire wheel Austin Healey 3
hondo402000 14 inch painted wire wheel any one need it Triumph 1
PATR8 Bought 15 inch rims for my 8 Triumph 3
PATR8 Wedge 15 inch rims for the TR8s Triumph 15
J Six inch rims on a Mk2? Jaguar 3
R6MGS MGB Biggest 15 inch tire for 80 MGB MG 9
AltaKnight What a difference an inch makes.... Triumph 5
beaulieu any skinny 16 inch radial tires 5.00x 16 or so ? Restoration & Tools 4
drooartz Spridget gauges, which are 4 inch? Spridgets 9
T TR2/3/3A Four inch wider TR3 photos available! Triumph 17
S TR2/3/3A tr3 - 9 inch rear brakes Triumph 1
C TR2/3/3A TR3A 10 inch rear brakes Triumph 7
M Oil Pan Gasket - 4 inch pieces? Austin Healey 2
bighly 3/4 inch sway bar bushing interchangability MG 2
S TR2/3/3A tr3 -- 7/8 or 1 inch slave cylinders Triumph 3
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M For Sale Vintage Modular HTN 3 Piece Racing Wheels 13" Triumph Classifieds 0
B Wheels and Tires Selection Austin Healey 10
F MGB-GT what do these wheels go to MG 1
CARSINC My Spyder-Mite Gets Wheels Spridgets 9
K TR2/3/3A American Racing Slot Wheels Triumph 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
T "Flashpower" Steering Wheels Austin Healey 3
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
