bigjones
Well, I'm quite pleased.
This morning I installed an MGB spacer block (yellow arrow) between the heat shield and carb.
This involved installing longer studs (from Ace Hardware) on the 1500 manifold and elongating the holes in the spacer so it would fit on the studs.
The spacer unfortunately moved the filter back at least an inch and the filter would no longer fit in there. By some miracle, the K&N filter housing from my 1275 (sob) fitted on the HS4 (just used smaller diameter bolts) and it actually lifted up the filter so I could use the original 3" deep filter. I put some play dough (plasticine) on top of the filter and carb but it was not, fortunately, deformed when I closed the hood.
Can't believe it - so simple. The engine fired right up and purrs like a kitten.
Also, angled the hose (blue arrow) from the valve cover to act as a road draft tube (as featured in the TR3) with wind from the fan in an attempt to get some PCV.
Cheers!
Cheers!
