100-6 shroud opening for grille question
YesIstillhavethe
This is about the BN6 100-6 cars and probably no different from the others but I would really appreciate info from 100-6 owners and restorers.
I have owned a 1958 100-6 serial 630 for over 40 years. The car has been in storage for the vast majority of that time. Now it is undergoing a total restoration.
There is a small slot or cut or corroded slit on each side of the grille opening approximately where the lower U shaped edging ends on both sides. The hole is about 1mm wide by about 5mm long. It is right against the return bend that the lower stainless trim piece goes over, one on each side of the grille. If it was a clock face it it would be at about 4 and 8.
If it was corrosion I would expect that the area all the way across would show signs of corrosion. Since the car has been stored in the typical garage conditions I would imagine that this may not be corrosion.
So maybe it is a opening for the ends of the lower trim piexe to go in?
Whaddaya think? Built that way or ended up that way? Thanks!
richberman
I've got a '57 100/6 BN4 with no slots. Here are some pictures of mine stripped.
rich
My 57 bn4 has no slots....
Larry
D 100-4 shroud Austin Healey 1
R 100-4 bonnet to shroud buffers Austin Healey 2
R Windshield to shroud rubber 100-4 Austin Healey 21
Y Restoring a 58 100 six front shroud Austin Healey 1
M Electric fan and shroud for a 100 4 Austin Healey 3
T 100 Front Shroud Attachment Austin Healey 0
timbn2 another 100-4 shroud... repairable? Austin Healey 15
timbn2 Front Shroud for 100 Austin Healey 2
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
