Spitfire Insulation
FlyingCat
Eventually I'm going to get my 1980 Spitfire back from the painters, and then it will be time to put it all back together (just in time for Spring!). I'm going to need to insulate it -- for sure against heat, and possibly for sound. Any recommendations?
Gerald_Gordon
Heat had not been a problem with my TR4, but at 60 m.p.h with the hood installed and the windows up, the resonant frequency of the stock exhaust system at 3000 r.p.m. generated a loud booming sound in the passenger compartment. (The car lacks overdrive.) Applying Dynamat Extreme > Automotive Soundproofing & Heat Control | Dynamat < to the floor and firewall and covering it with a layer of Dynapad > Heavy Duty Noise and Heat Reduction | Dynapad | Dynamat < in place of the stock jute pad yielded a noticeable reduction in that noise.
Patrick67BJ8 Insulation and Sound Deadening Austin Healey 0
Walter74 Insulation set from Koolmat Austin Healey 3
EWD TR6 Transmission tunnel insulation Triumph 6
NutmegCT Garage roof insulation Restoration & Tools 37
Jim_Gruber Heater Box and Insulation for Bugsy IV Spridgets 8
Rut Bugeye bonnet insulation Spridgets 4
D Fire wall insulation Austin Healey 36
NutmegCT wet insulation Restoration & Tools 9
M TR4/4A Underhood/Bonnet insulation...Yes...No ? Triumph 3
maxwedge5281 under floor insulation Austin Healey 15
L 3000 BN7 insulation Austin Healey 11
H quick insulation paint color quesrion Austin Healey 7
Griz Cockpit Insulation Austin Healey 13
R Interior cockpit coatings and insulation Triumph 12
M Insulation Done [pics] Triumph 6
F Wire insulation damage under the dash - Bugeye Spridgets 5
R Another insulation question Austin Healey 3
B insulation to the footwell Austin Healey 21
andrea Insulation Austin Healey 6
S TR6 Hood insulation for 1972 TR6 Triumph 3
memphis Braided Wire Insulation Austin Healey 12
bighealeysource good heat insulation product Austin Healey 1
A 76 MIDGET CARPET / INSULATION / SEAT INSTALL Spridgets 11
B Floor insulation question Austin Healey 10
jhorton3 Interior Insulation Spridgets 17
T TR6 TR6 heat insulation recommendations Triumph 12
martx-5 Cloth Insulation Tape Triumph 4
Raymond Insulation MG 3
NutmegCT heat insulation - interior Triumph 22
R John loftus bj7 restoration firewall insulation Austin Healey 6
W MGB Under-hood insulation on the MGB MG 8
A Dynamat ?---or what interior insulation?? Triumph 27
chicken Floor pan insulation panel Austin Healey 7
RomanH Timing Cover Sound Insulation Triumph 6
A Sound/heat insulation with foil---which way?? Triumph 7
jerrybny Heat & Sound Insulation question Triumph 2
H SU insulation installed MG 2
H Need heat shield insulation MG 4
C Floor insulation Austin Healey 17
T HVAC box to firewall insulation? Triumph 0
C Heat insulation washers Austin Healey 6
S Lizard Skin Ceramic Insulation MG 0
D Sound Absorber / Insulation in TR-# Doors? Triumph 8
W Exterior Heat Insulation?? Austin Healey 20
L What to use for carb shield insulation? MG 5
Stinky Can't find old post about insulation/sound deaden Triumph 8
A MGB MGB insulation and ventilation MG 2
