TR6 Will TR6 wires fit an MGB?
ROADSTR6
I'm looking to "plus one" size my B's wheels. I'm thinking the TR6 wheels might work. Any ideas? I' would try it myself, but my '74 TR6 has steel wheels and my '69 B has wires. Let me know if you have any ideas. /ubbthreads/images/graemlins/savewave.gif
trrdster2000
Roadstr6, The wheels do have the same splines and will fit your hubs, but and thers's always a butt, the TR6 is 15 inch and the MGB 14 inch so you will have to play with the size tire to get in the well without having a clearance problem. Wayne
Geo Hahn
May be hard to find a BTDT but you could try to find a willing local TR6 owner with wires who would let you pull a wheel for a trial fit. Buy him lunch and don't make him come to your place and he'll probably accomodate you.
Mark Beiser
72 spoke MGC wire wheels on an MGB with slightly lower profile tires works well, looks sharp too.
Just don't go to overboard with the lower profile tires, if you get the tire width to wide, you will have problems with sidewall flex that will make the car handle like it has a flat tire. It cost me $400 to learn that once...
Get the size and profile right and you can have stiffer sidewalls and wider tred than with standard wire wheels without having to give up the wires.
manymgs
They will probably fit a CB roadster. I ran TR6 wires on my 74 1/2 bgt for a few years using 185/65/15 tires. worked well and looked good.
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
I TR6 TR6 heater blower wires -what are these wires for? Triumph 8
wingsandwheels TR6 green plug wires, '74 Tr6 Triumph 6
V TR6 TR6 Ignition Wires Triumph 14
N TR6 Clip wires on front brakes for TR6 Triumph 9
DNK TR6 TR6 wires Triumph 11
John_Mc TR6 TR6 mystery wires Triumph 3
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
