What not to do at 6800 RPM in 3rd gear...
ChrisS
Shift to second instead of fourth. So after my lovely spin that Nial caught on camera I was rushing a bit. A few laps later I mis-shifted to 2nd instead or 4th on the front part of the straight away. This is the result:
and
The valves were stuck in the piston when I pulled the head tonight. Guess I get to build another one. /ubbthreads/images/graemlins/lol.gif
WoooooooooWWWWWW! /ubbthreads/images/graemlins/eek.gif /ubbthreads/images/graemlins/eek.gif /ubbthreads/images/graemlins/eek.gif
What did that sound like?
Nasty indeed. Yep, what not to do in fact but now you can improve on what you had a bit.
Just put some Motor Honey, Liquid Overhaul, Slick 50 and STP in there and it will fix her right up!
That's probably not an ideal engine condition, now is it. Even I can tell that... /ubbthreads/images/graemlins/grin.gif
Good to see you're in good humor (now, at least) about it.
Guess the real question would be... right before it happened, did you say, "Hey, y'all - watch this!"?
Bum-MER!
Mickey
[ QUOTE ]
(snip)
and
(snip)
[/ QUOTE ]
Wow! Worse than anything I've managed to do so far though I have come close by leaving valve impressions in the tops of pistons before.
Also managed to spin a race 1275 to 9,100 rpm very briefly by doing the same thing -- accidently getting it into 2nd gear instead of fourth. Lost 5 psi oil pressure after that incident but was able to complete the season without a teardown. (Now's the time for the teardown to inspect things and replace bearings.)
At any rate, get started now rebuilding or building a new engine so as to avoid the last minute rush, anxiety, compromises, etc., etc. Starting now allows a leisurely and enjoyable pace!
We do do this for fun, right? /ubbthreads/images/graemlins/yesnod.gif /ubbthreads/images/graemlins/driving.gif /ubbthreads/images/graemlins/cheers.gif
Tim
OUCH......Not good!
Hope that wasn't one of those really pricey modified heads! /ubbthreads/images/graemlins/cryin.gif
Just had an awful thought. Was that the special head I let you beat me out of on ebay for less than 100 bucks?
No no, just the basic casting not reworked.
No Jack, it must have been someone else. That was just a stock smogged head that I cleaned up and installed Cooper S intake valves in. I had a funny feeling that I would do something stupid this year when I built the engine, so I kept it pretty simple.
The engine didn't grenade right after I over reved it; I actually got two more laps out of it. When I pulled the valve cover the #4 exhaust valve rocker arm was against the valve spring retainer. I assume that when I over reved it I lost one of the keepers and then the other finally came off and I swallowed the valve. From there it got ugly. The other pistons don't show signed of valve contact. I knew it was going to be bad when I pulled the carbs off and the intake was full of piston chunks. /ubbthreads/images/graemlins/jester.gif
Must have been Bugeye58 then. That's good, hate to see tough to find parts get distroyed.
Think it was a 12G295
It wasn't me, either Jack. The only head I've gotten from eBay was a 206, after you said you weren't going to bid on it past X amount. It didn't go for less than 100 bucks.
Jeff
Carlbanan56 MGB High rpm problem MG 27
drooartz 1275 cruising RPM Spridgets 5
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
S TR2/3/3A floundering At High RPM Triumph 29
K TR2/3/3A Only idles steady at 2000 rpm? Triumph 0
F TR6 Sputtering at low rpm Triumph 16
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
S Can’t get idle speed below 1300 RPM Austin Healey 28
J Zero oil pressure at 4000 RPM Austin Healey 24
vette Constant Engine Running RPM. Austin Healey 20
A rpm calculation Austin Healey 6
M TR2/3/3A Rpm's at 10? Triumph 15
AUSMHLY Timing, what rpm? Austin Healey 4
tinman58 General TR Ring Gear @ 6000 rpm's Triumph 6
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
RAC68 BJ8: 650 RPM steady Idle at 45 Degree advance??? Austin Healey 26
GTP1960 TR2/3/3A hesitation and missing between 2000 & 3000 rpm Triumph 3
GTP1960 TR2/3/3A Tachometer vs rpm analyzer? Triumph 5
S Max RPM Austin Healey 15
bighealeysource speedometer readings based on rpm's ? Austin Healey 10
S Overdrive 22% to 28% - RPM and Speed Austin Healey 1
pkmh Speed Reading vs. RPM Reading Austin Healey 7
doughairfield TR4/4A Intermittent vibration at 3000 RPM Triumph 2
Patrick67BJ8 BJ8 Tach Won't go past 2400 rpm Austin Healey 5
Mowgli81 RPM / TACH not working. Austin Healey 4
dcoplan How do you find accurate engine RPM? Spridgets 14
P TR5/TR250 Car misses over 2500 rpm Triumph 21
D 20,000 RPM Wire brush Restoration & Tools 5
Lynn Kirkpatrick Hi RPM Power Loss MG 5
V Idle RPM Austin Healey 6
R TR4/4A Tr4a rpm, with or w/o PCV Triumph 3
Tim Tucker TR4/4A TR4 High RPM miss Triumph 18
R Weber carb hang-up at high rpm MG 0
C charging problem at 3500 rpm Spridgets 6
A rough running after long idle or long low rpm driv Triumph 1
CraigLandrum TR2/3/3A TR3A RPM vs MPH Triumph 11
prb51 High rpm/speed miss Triumph 20
johnrip Wedge tr7 engine idle low RPM bounce Triumph 3
T RPM question Triumph 4
T Ratco high RPM idle part two Triumph 11
T Does idle RPM really matter?? Triumph 5
J BJ8 timing vs RPM Austin Healey 0
E TR2/3/3A TR3 cruising rpm Triumph 10
startech47 79 Midget Surges from 400 to 1000 RPM Spridgets 1
BOBBYR Idle RPM Austin Healey 9
19_again Gas bypass-low rpm's MG 5
T Idle rpm creep? Triumph 12
V Myth: run engine at 2200 rpm for 20 to 30 min Triumph 10
