Ratco high RPM idle part two
T
Tinster
This is NOT a major worry for me, just a puzzle I'd like
solved.
I installed the Ratco cable carb throttle linkage last
January 2008. Once I got my gas pedal adjusted the Ratco was very responsive. I liked it a lot. Still do, in fact.
But it was curious to me that my warm engine idle increased
800RPM to 1200+ RPM with the Ratco system.
fast forward: Today I installed Jeff Palya's brand spanking
new carb linkage, took out the Ratco, cleaned up the Ratco and reinstalled and fine tuned it.
Started the car and warm idle at 700 RPM. Gas pedal response with the Ratco is instant!! VROOM!!!!! WOW! I Like it.
Within a few minutes in the street my warm idle is back up at
1200+ rpm. If I take down the idle screws, the car will not hold cold idle with full choke. Stalls out.
What the deveil is going on?? Why the higher warm idle with the Ratco? Here's a photo of my install. Errors present?
thanks,
dale
Brosky
You can warm the car up and get it to idle at 1,200 RPM's with no problem, right?
Just disconnect the Ratco linkage at that point by taking the ball stud out and see if it drops down or stays there. Then it's go or no go for hunting a problem with that setup.
If it stays up with the linkage disconnected, you have other problems, like a vacuum leak developing when it gets warm and something expands. Or I'd look at your choke cable linkage and make sure that they are BOTH closing completely when warm. Is there a possibility that the linkage is binding before it even gets to the cable, like back where the fulcrum is bolted to the pedal shaft, causing the mechanical linkage to stay open before it even reaches the cable?
If not, the Ratco linkage is only a cable that you cut to length and installed it in a fixed position. It cannot move or grow or shrink and pull down on the linkage to cause the idle to increase when it gets hot, so how can it alone affect the idle?
Are these pictures taken with the air filter removed? Does this same thing occur with and without the air filter bolted on the car?
Please report back your findings as I don't think it's fair to blame a sponsoring vendors particular product for an issue like this if you find that it is something else. If it is a problem after all of this, then Tony should be made aware of the problem.
Brosky
Dale,
What is that steel solid cable going from the Ratco bracket to the front carb linkage doing there?
NutmegCT
Just a thought - when my warm idle was 800 after adjustment, then wouldn't drop below 1200 after a drive ...
... the gas pedal linkage that goes through the firewall had stuck while driving.
Finally figured it out when I discovered the idle dropped back to 800<span style="font-weight: bold"> <span style="font-style: italic">if I LIFTED UP on the pedal</span> </span>with my foot.
Just my dos centavos.
Tom
Brosky
Tom,
Good point. That is why I asked about a binding at the fulcrum or BEFORE it even got to the cable.
T
Tinster
Brosky said:
Dale,
Tag end of my choke cable.
Brosky
That isn't binding up on anything is it? It seems awfully long and why would you have it heading back towards all of that stuff? I'm just looking for answers like you.
What about the rest of my questions? have you disconnected the linkage with the idle at 1,200RPMs? Did you try lifting up on the pedal as Tom suggested?
I think that it has to be either mechanical of vacuum/heat related.
Platinum
Go for mechanical first... pull the pedal back with a toe. Then if that doesn't change things, disconnect the linkage as Paul suggests and try it that way.
It's a process of elimination. But usually it turns out to be some sort of physical "hang-up" rather than a dial-in of settings with what is described for idle on Amos currently.
NutmegCT
So Dale - what's the situation now?
What did you test/change/fiddle with?
Still have the idle problem after the "brake test" drive?
Tom
Brosky
Dale,
Looking down at the ball stud going through the linkage, it appears that it is on an angle of sorts. If so, why not move the cable and housing back a bit towards the inner fender well in the mounting slot below, to get it all aligned at more of 90 degrees angles? Or is the ball stud bent slightly?
Brosky
Does that mean that it's fixed, or what do we make of this latest turn of events?
martx-5 Tony's [RATCO] High Idle Triumph 16
F TR6 RATCO fuel injection Triumph 4
martx-5 General Tech Ratco Article Triumph 1
DNK Info About Ratco Triumph 12
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
Tabcon I have been RATCO-ized...finally! Triumph 17
C Ratco cable help? Triumph 12
T Ratco cable linkage - diagnostics Triumph 5
T Ratco Linkage PART TWO Triumph 15
T Gorilla Cross Member from RATCO! Triumph 14
D Ratco Throttle Linkage Triumph 8
T Ratco Cable + Heat shield Triumph 30
T Ratco carb cable linkage Triumph 21
T Ratco cable linkage review Triumph 5
B Anyone used Ratco shock in spring set up? Triumph 0
D Ratco Throttle Linkage Triumph 31
Brosky Ratco throttle cable installation Triumph 2
Brosky Ratco Cable Linkage install on Tri-Carbs Triumph 16
Brosky Throttle linkage from Ratco Triumph 35
michalotti_tr TR Frames - RATCO now has website Triumph 39
Carlbanan56 MGB High beam problems MG 4
Carlbanan56 MGB High rpm problem MG 27
G High Oil Pressure Austin Healey 2
P TR2/3/3A British High Torque starter Triumph 6
MikeAH100M High Temp Engine Miss Austin Healey 2
Carlbanan56 MGB High resistance MG 2
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
S TR2/3/3A floundering At High RPM Triumph 29
M High-Torque Starter Austin Healey 10
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
LAW75 High-Pitched Noise Austin Healey 13
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
B High-Torque Starter Rattling Noise Austin Healey 3
M 1275 too high? Spridgets 2
dougie Targa High Country 2021 Austin Healey 2
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
J Experience with High Ratio Steering Box? Austin Healey 15
R Speedo High Beam Warning Light Color Austin Healey 14
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY 64 front end too high Austin Healey 14
steveg High altitude mixture observations Austin Healey 4
R General Tech High altitude adjustments Triumph 3
R High Altitude adjustments Austin Healey 3
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
