Whenever I've had that kind of problem - a high load misfire - it's usually plugs.
The rest of the ignition system either works at such-and-such RPM or not, most of the time. But when loads come on, plugs fail first - assuming carburation is right, of course.
Have you tried a plug cut? While misfiring, clutch out and cut engine, remove plugs and study. You might see just one with misfire signs, or you might see, for example, high speed / load lean mixture signs.
