Water transfer decal on BJ8 air cleaners
sunkissedhealey
I'm replacing the water transfer decals on my 65 BJ8 air cleaners. I seem to remember that the decals are not supposed to be centered on the edge of the air cleaner (looking down upon them). Are the decals supposed to be "offset"? If so, left or right and by how much? If anyone has a photo, that would be great. Thanks.
Rob
I've looked at several pictures that I've taken over the years and poured over many Healey books for photos. Most show the water transfer decal centered on the edge of the air cleaners. I found a couple that were "off-center". Somewhere I read or was told that the decals are supposed to be off-center. However I learned this, it made an impression on me to remember it. It is one of those small details, and when you have the chance to get it right, try and get it right. Picky, picky, picky, I know. Maybe I'm all wrong on the off-center issue. Somebody is bound to know something about this (I hope).
Rob
Here you go
Thanks for the picture. Looks perfectly centered to me. Anyone know anything different? I haven't found anything in writing yet(just the previous post's picture and many others from books. Again, a couple were off-center).
Rob
Ro /ubbthreads/images/graemlins/jester.gif
Hi Rob,
The description in the concours guidelines and the pictures in the Anderson/Moment book show it centered. Perhaps the "offset" you have seen was "factory variance" aka "friday afternoon"? /ubbthreads/images/graemlins/grin.gif
Cheers,
John
Bingo on "Friday variance"--a few photos do show the decals off-center. I've looked at photos and asked others much more knowledgeable than myself (such as those in this forum). I need to put this to rest and go with "centered". If I find out otherwise, after a couple of years the water decals fade and crack, and thus will be replaced. I'm replacing the air cleaners after about 15 years, and it seems about every three or fours years I've replaced the decals due to "wear". Consider this thread closed--at least for now.
Rob
S Source for water transfer Coopers decals Austin Healey 0
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
D Water Valve Connection Austin Healey 4
T TR2/3/3A Moss uprated water pump Triumph 6
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
P MGB Zenith water choke gasket needed MG 4
T TR2/3/3A Water pumps/head cooling Triumph 22
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Aussiea40 A40 water pump British Motor Corp 7
A MGB Stuck water temperature sensor MG 26
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
shadowfever Water temp Spridgets 9
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
C TR2/3/3A Water pump issue Triumph 8
Lin Heater water valve question Spridgets 2
Editor_Reid Water Temp Gauge Austin Healey 5
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Water pump Austin Healey 5
Patrick67BJ8 Water filters Austin Healey 16
George Zeck Water Pump ? Spridgets 5
F New water pumps on the market Austin Healey 25
nichola TR6 Resurrecting a water pump, worth it? Triumph 7
D TR2/3/3A extra hole in my water pump? Triumph 3
C Water flow in heater? Austin Healey 5
JPSmit water pump installation Spridgets 6
Michael Oritt Water Pump Leak Austin Healey 41
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
F Water pump replacement on my BT7 advice needed please Austin Healey 18
S TR2/3/3A tap water will no antifreeze on new engine Triumph 2
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
Csarneson How do the outer sills [rockers] drain water? Austin Healey 7
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
dklawson New [to me] Compressor - Water & Auto Drains Restoration & Tools 14
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N BT7 water temperature sensor removal Austin Healey 13
F Removing oil and water guage from BT7 dash Austin Healey 17
K For Sale Triumph TR3 Water Pumps for Rebuild Triumph Classifieds 0
D TR2/3/3A TR3 water pump question Triumph 4
JimLaney Drain holes relieve wing water retention? Spridgets 3
S For Sale BJ8 Water pump for sale Austin Healey Classifieds 4
