TR2/3/3A Water Pump Belt After Alternator Conversion
mastaphixa
Bronze
I have purchased a Denso 12185N Alternator, had the original generator pulley modified to fit said alternator and now the original belt (from Moss) is so to short. Can someone please give me a belt pn that will get me in the ball park with this nice little 50A alternator?
Thanks,
Steve Baker
Not sure about belt part #'s, but you could always go to the FLAPS and see if they have or can order a belt the same width/profile in a larger diameter. Run a string around all the pulleys like a pseudo belt and measure the length of the string to get a good ballpark of the belt length you'll need.
Another option is to get a smaller pulley for the alternator. Part of the benefit of the alternator conversion is being able to run a smaller pulley because you don't have to worry about spinning the alternator faster at higher engine RPM. The reason the generator pulley diameter is so large is partly to prevent it spinning too fast. The with smaller pulley on the alternator you'll get much better charging at idle.
Robby
I have a list of some of the belts I tried on my TR3A with lengths. Will look for it i the morning.
I got the belt from O'Reilly.
David
Here's the one I use.
Seems that Goodyear has quit making them, but you can still find close-outs on eBay at a reasonable price. RockAuto has several equivalents listed as well.
PS, here's a shot of it installed. As you can see, the adjustment comes to the middle of the range.
Steve,
I have two Tr4's both are converted to alternators. One has a regular sized pulley while the other has a slightly smaller pulley ( this allows for the alternator to start producing power at about 600 RPM). I use a NAPA 28400 belt on both of these cars.
Here is the belt I used.
I have an alternator with a wide pulley, a new TRF water pump pulley and the original crank shaft pulley. All 3 pulleys are very slightly different widths. It is a tight fit to get it on but everything is driving on the flanges of the pulleys.
It can be removed without taking anything else off the car.
David
Thank you all for your responses.
Steve Baker
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
J Spitfire V-belt and water pump 78 Spitfire Triumph 0
Michael Oritt Water Pump Recommendations Austin Healey 1
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
T TR2/3/3A Moss uprated water pump Triumph 6
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Aussiea40 A40 water pump British Motor Corp 7
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
C TR2/3/3A Water pump issue Triumph 8
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Water pump Austin Healey 5
George Zeck Water Pump ? Spridgets 5
nichola TR6 Resurrecting a water pump, worth it? Triumph 7
D TR2/3/3A extra hole in my water pump? Triumph 3
JPSmit water pump installation Spridgets 6
Michael Oritt Water Pump Leak Austin Healey 41
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
F Water pump replacement on my BT7 advice needed please Austin Healey 18
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
D TR2/3/3A TR3 water pump question Triumph 4
S For Sale BJ8 Water pump for sale Austin Healey Classifieds 4
Got_All_4 TR2/3/3A Water Pump "Here I Go Again" Triumph 61
G Water Pump Failure - Diagnostic Steps? Austin Healey 16
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
Got_All_4 TR2/3/3A Water pump problem Triumph 7
Gordon_Dedrick TR2/3/3A TR3 Water pump replacement Triumph 5
C Healey BN6 water pump and overheating problems Austin Healey 11
K TR4/4A Water pump and water pump housing bolts..... Triumph 3
A TR2/3/3A Uprated pulley kit with uprated 6 blade water pump problems. Triumph 7
histerical Water Pump Spridgets 1
D TR4/4A water pump mystery hole Triumph 6
T TR2/3/3A Water Pump Housing Bypass Triumph 11
B TR2/3/3A end of me water pump thread Triumph 2
B TR2/3/3A Replacement or rebuild kit for water pump Triumph 11
B TR2/3/3A Water pump color Triumph 4
vickxxx TR2/3/3A new water pump noisy after 6 months Triumph 5
matmire Replacement Water pump issue Spridgets 5
2 TR2/3/3A Classic Gold TR2-4 water pump Triumph 5
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
Got_All_4 TR2/3/3A Water pump dissasembly Triumph 10
L Trouble refitting pulley to new water pump Spridgets 9
JFS TR2/3/3A Bad Water Pump Triumph 11
