Valve adjustment 'how-to- on YouTube?
tdskip
Went looking for a video but came up blank.
I think it would be a fantastic resource if we all filmed and posted some of the basic maintenance items and posted them.
I get lots of people would find it helpful.
Here's the procedure on the TR6. Not YouTube, but pretty clearly stated.
Mickey
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
G Valve adjustment and easiest way set cam position Austin Healey 15
S TR2/3/3A All new valve train - no adjustment at rocker arms Triumph 12
K TR2/3/3A Valve Adjustment? Triumph 17
L TR6 Bypass valve adjustment Triumph 1
wangdango BJ8 valve adjustment? Austin Healey 3
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
Boggsy64 MGB Valve adjustment MG 6
Darwin GT6 GT6 Valve adjustment Triumph 6
nevets Valve adjustment intervals? Austin Healey 15
6 Valve adjustment stock 948 Spridgets 11
glemon Valve Adjustment/Wear Triumph 4
Rut 1275 valve adjustment Spridgets 10
Rut timing, cams, valve adjustment Spridgets 6
BOBBYR VALVE ADJUSTMENT Austin Healey 1
G MGB MGB valve adjustment MG 3
M 1275 valve lash adjustment "shade tree" Spridgets 10
Marvin Gruber Valve adjustment Part 2 Jaguar 11
Marvin Gruber Valve adjustment Jaguar 15
I Valve adjustment basics - help please Spridgets 21
M valve adjustment? Triumph 5
I TR6 TR6 valve adjustment help Triumph 3
Woodie valve adjustment Spridgets 5
66healey Valve adjustment Austin Healey 11
newmexTR3 valve adjustment q's Triumph 4
R Valve Adjustment Question Austin Healey 12
malice Valve Adjustment Triumph 2
TRclassic3 TR2/3/3A TR3 Valve Adjustment Triumph 10
H Valve adjustment question MG 10
M TRactor Motor Valve Adjustment Sequence Triumph 5
sparkydave How sensitive is the valve adjustment? Spridgets 11
B valve adjustment Austin Healey 7
R Valve adjustment Austin Healey 6
S Valve Clearance Adjustment Austin Healey 17
M Valve adjustment MG 12
J Valve adjustment help. Triumph 5
tahoe healey valve adjustment Austin Healey 14
Y MGB Do I need a heater valve? MG 1
K TR2/3/3A Installing silicone valve cover gasket Triumph 6
BierRunner TR6 Thank You - Heater control Valve Replaced! Triumph 1
BierRunner TR6 Removing the old Heater Control Valve Triumph 2
AngliaGT '97 Miata - Need to Replace the EGR valve - recommendations? Other Cars 7
K TR2/3/3A Valve rocker shaft questions..... Triumph 11
K TR2/3/3A Cylinder head valve stems and guides.... Triumph 3
BierRunner TR6 Heater Valve Triumph 20
Carlbanan56 MGB MGB valve seals MG 1
TomMull Valve lash Lotus 6
S TR2/3/3A tr3 valve spring compressor Triumph 5
R Valve Drain Pipe Austin Healey 13
