TR7 SU Conversion- Request to the MG Guys
I posted this over on the Triumph side but thought I might post here as the real issue is an SU question more than a Triumph question.
The original thread is at:
https://www.britishcarforum.com/bcforum/ubbthreads.php/topics/868332/TR7_SU_Conversion#Post868332
I am in the process of changing out the Stromberg's to SU's on the TR7. I have a question related to the throttle linkage between the two carbs. There is a solid bar that joins to two carbs together. When put in place it is extremely tight, almost binding and I see no adjustment. The linkage and carbs came off of a British TR7 and it is tight when put on the original British manifold.
Question: Is there an adjustment for that bar longitudinally? Is is supposed to be that tight?
Any advice before I start shaving off metal would be greatly appreciated!
It should "float" before the two are synched.
Got any photos?
The two center linkage bars when everything is installed should have a little side to side play, if not, this can cause binding, the most common issue is the two lever arm that activae the side linkages on the carbs might be too close agaisnt the side of the carbs, not allowing side to side play. The other issue could be the round bar itself could be a tad long, and need to be shortened, but try adjusting the two lever arm inboard a tad before shortening the the round center bar itself. Hope this helps.
Update- Problem fixed by a little judicious use of the file on the bar. Appears to be working fine. Now on to tuning.
Thanks for all the input.
Dave B
:thumbsup:
johnrip Wedge TR7 led light conversion question Triumph 1
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
A Wedge TR7 SU Conversion Triumph 11
mgbmedic Wedge TR7 V8 Conversion? Triumph 12
DanNagy Wedge TR7 Buick Conversion Triumph 23
johnrip Wedge tr7 sprint conversion Triumph 2
johnrip Wedge tr7 sprint 16v conversion kit Triumph 0
DanNagy Wedge TR7-Saab Conversion Triumph 15
A Wedge Can you tell me about this TR7 Weber conversion? Triumph 3
T Wedge Need a Triumph TR7 FHC for a TR8 conversion? Triumph 13
PATR8 Wedge TR7 to 8 conversion Triumph 16
C Wedge TR7/8 conversion...worth it? Triumph 10
T Wedge TR7 conversion Latest. Triumph 7
T Wedge TR7 Jag IRS conversion Triumph 9
Got_All_4 Wedge TR7 Speedo Problems Need a Repair Place Triumph 2
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
