Alabama_Hokies
Member
I am in the process of changing out the Stromberg's to SU's on the TR7. I have a question related to the throttle linkage between the two carbs. There is a bar that joins to two carbs together. When put in place it is extremely tight, almost binding and I see no adjustment. The linkage and carbs came off of a British TR7 and it is tight when put on the original British manifold.
Question: Is there an adjustment? Is is supposed to be that tight?
