TR6 TR6 - alternative linkage design?
tdskip
Hi guys - doing some fun reading and came across this on TR6 under improvements - "Talking of one-off outlays, Revington TR markets a special throttle linkage which adds real power to your right foot. The problem is wear and slop in the original design says the Somerset specialist meaning some cars only work on less than half throttle! "
Anyone familiar with this issue / fix?
Hi Mike, wasn't aware that Ratco offer that. They mention the same wide open issue so maybe there is something to it.
How to best check you are getting full travel?
There is a throttle stop on the carb's 'throttle stop lever'
Put a weight on your accelerator pedal so it's floored and see of the throttle stop lever contacts the WOT stop.
If it doesn't adjust the linkage as per instructions in both Bentley and Haynes.
If you have those to spec and still do not get WOT, then you need to reposition the accelerator shaft "control lever" Moss 676-035.
In this series of photographs you can see the throttle stop with a yellow background.
IDLE POSITION
HALF THROTTLE (shows up good)
FULL THROTTLE (within a hair of WOT, my grip loosened)
Notice the throttle stop just about touching the cast WOT stop projection and the actual throttle disc almost perpendicular to the throat of the carb.. If my grip had not loosened as I snapped the picture it would have been at WOT
BobbyD TR6 TR6 and other TRs - Brake Light Switch Alternative Triumph 7
Coyote1 TR6 74 TR6 Front Turn Signal Alternative Triumph 9
tr6web TR6 TR6 Manifold gasket help Triumph 0
mctriumph TR2/3/3A R&D completed on Tr6 fan conversion Triumph 2
Hawk813 TR6 TR6 Brakes Triumph 5
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
