BRSLimited
I just purchased a TR4a titled as a 67 but I suspect may have been a 66 by the commission number. Pulled the numbers off the commission tag and it's body 26 (wedgewood blue) trim H16. Any idea what this is supposed to be? I've never seen a trim code start in a letter and none of my literature even gives 16 as a valid number. The car was last registered in 98 and has not run since. Some fresh gas, cleaned the points, and a coil and she fired right up. Carbs need to be cleaned though. In looking the car over it's showing 50K on the odometer and from the looks of things I'm believing this might be actual mileage. Believe it or not EVERYTHING on the car still works, all the lights, turn signals, guages, ect. I've seen so many of these things that don't work after just sitting through a winter let alone 12 years. I'll post some pictures when I get a chance to.
