TR4/4A TR4A A-type overdrive and Moss Europe TR2-4A cat.
HerronScott
So I didn't realize the TR4A had a different A-type overdrive assuming the following information from the Moss Europe catalog is correct. I think this was a change in the accumulator.
OVERDRIVE UNIT, (series 22/61275) TR2 To TS5979
OVERDRIVE UNIT, (series 22/61374) { TR2 From TS5980, TR3-3A} TR4 (To October 1964)
OVERDRIVE UNIT, (series 22/61712) { TR4 (From October 1964)} through TR4A solid rear axle
OVERDRIVE UNIT, (series 22/61753) TR4A IRS
Note: Overdrives can be interchanged as complete units. It is not recommended that 22/61275 is used on later cars, as it is hydraulically incapable of handling any ‘extra’ torque, especially in 2nd and 3rd gears. It is, however better than nothing, and if used on later cars should be restricted to 4th gear use only. 22/61753 is the only safe unit to use on the TR4A IRS, as none of the earlier units feature the ‘cushioned’ engagement. This modification was introduced in 1965 to smooth out engagement, it also lessened the likelihood of the engagement to rip the differential mountings off the chassis.
I found Moss's Restoration catalog to be pretty interesting and wouldn't mind have a printed copy.
Moss Europe TR2-4A catalogs
cott
The Moss catalogs are definitely a useful reference, but I wouldn't regard them as gospel.
For example, it's fairly trivial to convert an earlier OD to use the later accumulator arrangement; and in fact this is sometimes done to save a housing with a damaged accumulator bore. Some folks also like the harsher engagement, so occasionally you'll find one that has been converted back to the large accumulator. (The Healey folk consider this a "performance" mod.) So the number on the plate doesn't necessarily indicate the presence (or absence) of the smaller accumulator.
Besides which, it takes only a modicum of care to avoid shocking the driveline.
Another example, there are many ODs originally fitted to TRs that don't have one of the above numbers. I believe the '6' after the '/' in fact indicates a factory rebuilt unit; and many cars don't have that digit. Some cars have a '2' instead of a '6' (which may indicate a manufacturing location).
Randall,
I never had any problem with the TR3 overdrive I installed on my rebuilt TR4A transmission in the course if 75,000 miles or so (with the earlier accumulator).
I certainly wouldn't take the catalog as a definitive source, but it's much more interesting than the Moss US catalog.
Scott
A TR4/4A TR4A overdrive A-Type and "dual" Stebro exhaust Triumph 5
britlover TR4/4A Where can I get an A-type TR4A Trans rebuilt in SE Michigan? Triumph 9
T TR4/4A White wire question on TR4A A-type wiring Triumph 2
T TR4/4A TR4A - A Type OD Solenoid - need a bit of help Triumph 7
T TR4/4A Is this the correct trans mount for a TR4a A-type Triumph 5
T TR4/4A Checklist for installing A-type O/D in TR4a Triumph 40
P TR4/4A gearbox exchange TR4A to J-TYPE Triumph 5
T TR4/4A Triumph TR4A 1965 price Triumph 8
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
