TR4/4A TR4 wiper question
SCguy
On my TR4 wiper motor, I'm missing the nut and then tubing which the cable to the wipers runs through. In other words I have the motor with drive cable only. Can the tubing be locally sourced? What about the nut which holds the tubing to the motor? Is there something special about the end piece of the tubing?
My recollection (don't have the car here) is that was sort of a compression nut and the end on the tubing had a flare... i.e. the nut wouldn't slide off the tube when it was disconnected.
The tubing may be something you can fabricate from fuel line but that nut is another story -- think you may be calling upon someone with a parts car or trolling evilBay.
The first bit of tubing has a couple of curves in it and a bell-shaped flange each end so the nut will retain it at the motor end and to position thedriver side wiper gearbox.
I have read you can use ordinary "bundy" pipe as used for brake or fuel lines, and bend it as needed with the cable inside to prevent the wall of the tube from collapsing or kinking. You would then flare the ends with a flaring tube.
Alternatively you may be able to buy these things locally, either new or used.
If all that fails I happen to have a spare tube, and I think nut, though you are not exactly in the neighbourhood!
Simon.
Larry-
It's a crying shame you can't find a good rust bucket parts car for under $1000 - it would be a treasure trove of just these kind of parts. And I think in the long run you'd save a bundle too.
Randy
I think that is the blessing and curse of being out in California - you picked up a great car with your latest purchase but as you aren't living in the rust belt you will have a little harder time getting that donor car..
Maybe this will help. The tubing may be tricky, especially without the stock pieces to compare. I had my entire dash out a few months back, so naturally I had the tubing out, too. As you probably know, the tubing links into the slots in the wheel boxes. As I recall, the flaring looked fairly simple and could be done with a standard flaring tool, and the tubing appeared to be like simple fuel line.
Someone may correct me, but the tubing seems to do nothing other than hold grease and guide the drive cable. I think that with the wheel boxes in hand, and the measured distance between the two, you could make the tubing with a flaring tool and be just fine.
As for the nut, I'd think that a good shop that carries specialty auto fasteners (like Scott Supply in Tucson, or Arizona Bolt and Nut) might carry it. Moss calls for a ferrel, but I think the tubing was flared at that end, too--it's definitely flared at the wheel boxes because that's how the tubing is held into place.
Hope this helps. If I were you, I wouldn't be afraid to make them on your own. It could be a fun assignment if that nut is available. I suppose the threading could be an issue if it's whitworth. Best of luck.
SCguy TR4/4A TR4 Wiper wiring question Triumph 7
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
pa297pass TR4/4A TR4 wiper motor rubber mount installation. Triumph 7
KVH TR4/4A TR4 Windshield Wiper Motor Issue Triumph 8
Alan_Myers TR4/4A Wiper motor for TR4 Triumph 2
C TR4/4A New 1961 TR4 questions Triumph 2
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 18
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
