TR4/4A TR4 SVRA Watkins Glen in car
MadMarx
The chicane situation at about 8:30 is quite tight. I really doubted that it turns out well.
How does it come that these MGBs are so fast? Or aren't hat Bs?
But great stuff and very well driven...good action.
Hot did it come that he was on the back of the grid at the start?
Cheers
Chris
M
Monkeywrench
Cheers
Chris
The pass in the bus stop was more akin to NASCAR, but it turned out okay. All the drivers were all smiles at the end of it. You can see when the Lotus gets by again, he points ahead.. which usually means "lets work together and get to the lead".
The blue car is a MGB and that's the fastest one in the country hands down. It also doesn't help he's using Kumho V700 and the Triumph had 5.5" Goodyear Bluestreaks.
You can read a little about it here https://classicmotorsports.net/articles/rivals-speed-mg-vs-triumph/ (Dave Headley) and it's the yellow car https://www.youtube.com/watch?v=n39gDXnLF4o running 3rd overall just behind the 400hp V8 MGB GTs
The starting position is a pretty funny story. Dick qualified in 3rd oa for the Qualifying Race. During the qualifying race pace lap, the car died and he dropped near the back (about 40th), he worked his way up to 7th oa, but was penalized 12 positions for a single pass under yellow. So he had to start 19th on Sunday.
angelfj1
Chris:
Good questions. Wouldn't the mgb and the TR be in different classifications according to SCCA (in the 1960's)?
M
Monkeywrench
They are. TR4s were in DP and MGBs were in EP. Tires are a big part of it, and we've been complaining about it for years. Being allowed a decent R-compound radial would automatically be worth 1-1.5 seconds per lap, which would put the TR about even with the MGB. You can see how the MGB can outbrake the Triumph and use less track to get around the corner. The MGB will always out handle the TR.. it's wider, lighter and has better suspension geometry, just like the TR should always be faster in a straight line (400cc more and an 8 port head). That's kind of what you're seeing there.
MadMarx
Seems that the Goodyear tires are comparable with the Dunlop racing tires they use for vintage racing over here.
We in our group use the Yoko A048 tire which is much cheaper and better drivable tire and it last longer too.
The MGB's aren't that fast in Europe I would say.
The Triumphs are blown down by the Lotus Elan cars.
But again - a real lesson for driving a Triumph.
HerronScott
Pretty awesome to watch! I was wondering about the other cars in that pack so had to go look up the results. I recognized the Lotus 7 but didn't recognize the Datsun Bluebird.
2009 SVRA Watkins Glen Group 3 results
Anyone know what the differences are in the classes? The TR4, Datsun 2000 and Lotus 7 were all 3CP while the 2 MGB's were 3DP and the Datsun Bluebird was 3BS.
Scott
M
Monkeywrench
I'm snowed in so you'll get a quick response.
The 2.0L Datsun and Super 7 are "new" DP. They came in the late 60s and were faster than the TR4s, which were subsequently bumped down to EP. With 2 x SUs the TR4 runs 3DP, but the camera car has 2 x DCOEs, so it's bumped up a class. The MGB has a weber on it, but since it only has two intake ports (2 SUs = a single DCOE according to the rules), it doesn't gain any more airflow, and isn't bumped up a class.
M_Pied_Lourd
We need to see a Capri out there :smile:
Cheers,
M. Pied Lourd
MadMarx
A Capri? I would say Dick would have some trouble to fight against a Ford Capri:
48KfnCA&feature=related" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
<embed src="https://www.youtube.com/v/d-NdKKjHBN8&feature=related" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
M
Monkeywrench
Some old ones from 2005. Had some fueling issues that couldn't be fixed at the track (knew what it was, just didn't have the pieces to fix it). Also on old 'chainlink' tread Vintage TDs. Similar to the Dunlop vintage tire for the European guys. Lap times are about 5 seconds a lap slower from where this car and driver run now.
Qualifying race. Motor is breaking up due to the fueling issues, but still trying hard for the first few laps.
Still same issues, but holds it together long enough and makes a real race out of it. Great back and forth with Randy Williams' TR3 and comes down to the last corner. Lost a pin in the oil pump at the end.
luke44
Wow. Thanks for reviving this thread. These are great videos for a racer-hopeful like me. A few more views and I think I'll have WG figured out. I hope to catch up with you in Sept if your are going to be there.
M
Monkeywrench
Bruce,
Those are a friend's car. A bunch of us help out with it at the race track. He's on the computer, but not real computer savvy, so I upload the videos for him. You can also see more photos here: www.the71crowd.com . Here's an article a good friend of mine wrote about the driver: https://thechicaneblog.com/2013/02/11/dick-stockton-a-life-in-racing/
I have videos all over the place, but I guess I can consolidate them in this thread:
1963 Triumph TR4: 2200cc, car weight ~2200lbs w/ driver . Fast Lap 1.36.8, Pole car: Lotus Super Seven, 1500cc, 1175lbs per rules w/o driver. Fast lap 1.36.6 . Keep in mind the Super 7 weights some 850lbs less per rules.
This was the very first public event ever held on NJMP's Thunderbolt circuit. 100+ degree weather and a brand new, never rubbered in track made for some treacherous conditions. Gear oil was dumped on left side of track from turns 5-8 during the pace lap, which is why they aren't using all the track through that section.
Camera car: 1963 Triumph TR4, ~ 2200lbs w/driver, 205/60/15 Hoosier Speedster tires. Fast Lap 1.37.4 ,Red car: lightweight Morgan 4/4 with a 1600cc crossflow engine. Fast lap 1.37.0 . The Morgan has to weight about 1450lbs per rules, not sure how close that one is to that number.
M
Monkeywrench
Here is a another:
Both drivers go way back. The other car is Bob Leitzinger's L18 (1800cc) Datsun 510. Weighs a little less than the Triumph and has better tires/ chassis. A good race until the end. The Triumph is on Hoosier Speedsters. That tire isn't as fast as the bias plys the competition is on. That topic is a can of worms... :rolleye:
TR4nut
Bob-
I love watching these. Thanks!
aeronca65t
We've been going to The Glen for Fall racing since '01 (the old EMRA event date in mid-October which was handed over to VRG in '07).
It's a smaller, low-key event than the SVRA weekend with tons of track time, great Fall colours and cooler temps (OK...it actually snowed once a few years ago!). Peter Egan has attended this VRG event....it was great fun chatting with him and we're hoping he'll be back. (he wrote about it in R&T).
My first visit to The Glen was '68 to see an F1 race (Stewart was first, then G. Hill second with Surtees in third).
I know the place pretty well. I've probably got 500+ laps there and have run three 3-Hour enduros there plus other lots of other stuff. But it's not my favourite track (it's a big too big for a small-bore car). Nevertheless, we always have a good time there.
We never miss a visit to the Seneca Lodge with friends and sometimes go to the Glen Motor Inn as well.
I know Linda is going out with lady-friends on our next race there to visit the various winerys (there's about 100 around Seneca lake).
Here's a much more sedate video than the TR above, from onboard my 65 horsepower Sprite. :friendly_wink:
Since you guys are Triumph guys, here's a photo of the first TR8 I ever saw (at Lime Rock-1980)
M TR4 SVRA NJMP Racing 4
M TR4/4A 2011 SVRA NJMP TR4 in car Triumph 6
M TR4/4A SVRA NJMP Triumph TR4 in-car Triumph 3
C TR4/4A New 1961 TR4 questions Triumph 2
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 15
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
