TR4/4A TR4 seat buffer problem
Trackle
So I am reupholstering some seats from a TR4, they were in pretty rough shape. Once I had all of the material off and the frame stripped I noticed that one of the two frames was missing one of the seat "buffers". The part is unavailable and I'm at a loss about where to go from here. Does anyone know if there is a comparable part, or a good solution to this problem? The other 3 buffers are rusted to the frames so they are going to be a pain to remove but I will replace all 4 if I need to. The TR6 buffers do not fit where these are supposed to sit on the track. I've attached a picture of the buffer I'm talking about.
mctriumph
Rubber bits can be simulated with 3M windshield urethane as it will bond to any clean surface.
Usually 4a seats require a lot of welding too. Good luck!
Mad dog
Tr6easyrider
T
Trackle
How about this. They look the same .
Whoever had done these seats before me had put the TR6 buffers on there instead, but unfortunately they are about twice as thick and so they had drilled them into the frames beside where the originals were so that they would end up beside the tracks, which is a) why 3 of the originals are still on the frame, and b) made it to where the buffers were on the carpet and making it impossible to adjust the seat forward and backward. If I put them where the original buffers are they are too thick and force the seat back forward at a bad angle. The originals that are on the frame are some sort of hard plastic, they aren't rubber. I had seen the TR4 buffers from East Kent Trim Supplies but they look like they are the same size as the TR6 buffers, and their website doesn't give a description or show them with anything to scale them.
Sarastro
You don't need to use precisely what the factory used. I used bumpers from McMaster-Carr. See
> McMaster-Carr <.
I bought part no. 9540K752. I used these on both the seats and top frame. $6.93 for ten, now $8.63. (Sigh...)
R TR4/4A Early TR4 seat pans Triumph 26
charleyf For Sale TR4 seat covers -new Triumph Classifieds 0
O Wanted 1962 tr4 seat rails Triumph Classifieds 0
M TR4/4A TR4 with Surrey Top......Rear seat upholstery assistance please. Triumph 2
Zitch TR4/4A Early tr4 Seat refinish - horse Hair for Foam? Triumph 7
J TR4/4A TR4 H6 float chamber needle & seat assembly Triumph 2
R TR4/4A tr4 / tr4a seat frames Triumph 9
TR4A_IRS TR4/4A 3 point seat belts on a TR4? Triumph 10
SCguy TR4/4A Early TR4 Seat Tracks Triumph 2
M TR4/4A TR4 Seat Belts Triumph 4
S TR4/4A TR4 Seat Replacement Triumph 11
SCguy TR4/4A TR4 Seat tracks Triumph 6
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech Issues with Distributor--TR4 Triumph 13
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
