TR4/4A TR4 Seat Belts
mylesw
Hello
For obvious reasons I want to fit some decent seat belts to my TR4. I have seen the intertia type as well as the three and four point harnesses. Does anyone have any pictures or diagrams of how these different types of seat belt would be installed?
Thanks
Myles
Geo Hahn
mylesw said:
... as well as the three and four point harnesses...
Myles -- lots of differing opinions on this, but you might think about whether you want to be strapped in an upright position in an open car with no roll bar.
Andrew Mace
One thing is for certain: you do NOT want a full four-point harness UNLESS you have a good -- preferably someone's sanctioning body competition-approved -- roll bar, properly mounted! A more common three-point harness is ok in an open car, as it does give you (at least in theory) the option of being able to slide out from under the diagonal shoulder portion in the event of a rollover.
As for that three-point setup's shoulder belt mount, said shoulder mount really has to be at or above shoulder height; otherwise, there is a very real possibility of spine compression in an impact. Where the inertia reel shoulder belt guide mounts on a TR6 is ok; anything much lower than that for intertia or static belt is not.
TR3driver
Great Pumpkin - R.I.P
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif Worth mentioning perhaps, that many of the "roll bars" on the market are only for show. Anything that is 'real' will be attached to the frame, not just sheet metal. And since the frame is well inboard of the doors, a 'good' roll bar will also intrude significantly on the passenger compartment.
CinneaghTR
Search the forum and you'll find a thread I started a few weeks ago about TR4A seatbelts, which includes photographs, drawings, and similar comments to the above from our fellow (and generous) forum members.
I went with the three-point static harness with snap ends from Moss. They are American made by Beam's in Oklahoma.
Good luck.
TR4A_IRS TR4/4A 3 point seat belts on a TR4? Triumph 10
T TR4/4A TR4 seat buffer problem Triumph 5
R TR4/4A Early TR4 seat pans Triumph 26
charleyf For Sale TR4 seat covers -new Triumph Classifieds 0
O Wanted 1962 tr4 seat rails Triumph Classifieds 0
M TR4/4A TR4 with Surrey Top......Rear seat upholstery assistance please. Triumph 2
Zitch TR4/4A Early tr4 Seat refinish - horse Hair for Foam? Triumph 7
J TR4/4A TR4 H6 float chamber needle & seat assembly Triumph 2
R TR4/4A tr4 / tr4a seat frames Triumph 9
SCguy TR4/4A Early TR4 Seat Tracks Triumph 2
S TR4/4A TR4 Seat Replacement Triumph 11
SCguy TR4/4A TR4 Seat tracks Triumph 6
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
