TR4/4A TR4 Seat tracks
SCguy
I've been looking for seat tracks for my TR4. They are the ones that are NA from Moss as show in the picture (#2). Does anyone know if either of the other seat rails work?
G
Why wouldn't #4 work, Larry? Same floorpan as our 6. Threaded holes in floor should be the same. I know TRF has them (the one-piece units).
DNK
Mine is assessable and can do all the measuring you need.
Larry Envelope goes out on Monday with shipping included.
pa297pass
Hi Larry:
My '62 TR4 uses the TR6 type seat rails. They bolt directly into the original holes in the floorpan. I don't have original TR4 seats (metal pan style), I have a set of TR4A seats. These seats are similar in construction to the TR6 seats.
I will post pictures of the seat rails installed if you'd like.
Matt
pa297pass
SCguy said:
I guess what I'm trying to find out is, can the newer style seat rails be used with the older early TR4, late TR3 seat pans?
Larry:
I don't know how those seats mount, but here are a couple of pictures of my setup ...
Seat Track:
Seat Bottom:
The dimension on the first picture is <u>between</u> the two seat mounting brackets ...I think the seat actually bolts to the outside of these brackets.
Hope this helps.
Matt
SCguy TR4/4A Early TR4 Seat Tracks Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
R TR4/4A Early TR4 seat pans Triumph 26
charleyf For Sale TR4 seat covers -new Triumph Classifieds 0
O Wanted 1962 tr4 seat rails Triumph Classifieds 0
M TR4/4A TR4 with Surrey Top......Rear seat upholstery assistance please. Triumph 2
Zitch TR4/4A Early tr4 Seat refinish - horse Hair for Foam? Triumph 7
J TR4/4A TR4 H6 float chamber needle & seat assembly Triumph 2
R TR4/4A tr4 / tr4a seat frames Triumph 9
TR4A_IRS TR4/4A 3 point seat belts on a TR4? Triumph 10
M TR4/4A TR4 Seat Belts Triumph 4
S TR4/4A TR4 Seat Replacement Triumph 11
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
