TR4/4A TR4/6 Baffle Plates aka Splash Guard bolt-on only?
tdskip
It looks like it, but wasn;t sure if there are any points where they are welded to the inner fender.
Part # 39 & 40 here;
Part #24 & 25 here,
Popeye
Bronze
I believe it is just a bolt-on...probably someone more intelligent than I can comment? I have the parts but have not installed them yet.
Mike
66 TR4A
G
Indeed they are just bolt-on. TRF makes a nice replacement set that are powder coated. A thought for anyone with either a TR4 or 6, consider taking you old ones out and replacing with new. Cheap enough. But what you might find inside the fender cavity is priceless. Hopefully no rust but know that the scuttle vent dumps right into this area and drains down into small gaps where the rocker and fender join. Not, IMHO, a good design and a potential for major headaches. I was fortunate in that mine only had surface rust and was able to scrape, treat and repaint. Too, instead of having the scuttle drain into this cavity, I extended a new rubber hose to exit down to the front bottom lip of this panel and dump water into the wheel well. Works well. A nice weekend project.
71tr
I did the same thing as bill when I had my fenders apart. Just extended the existing plastic drain pipe to dump the water directly rather than let it slop around inside the fender in the hopes of finding an outlet.
TR6oldtimer
The the catchment between the hood and firewall also drains into the area behind the front fenders. Nothing you can do here. Do not plug the holes into the fender void, as they are needed to vent the area as well as drain water.
T
tdskip
Thanks Ray.
So I removed the drivers side one, and despite cleaning and heating/cooling the bolds to help them break loose the bolts snapped.
Cool! (not really)
C TR4/4A New 1961 TR4 questions Triumph 2
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 14
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
