TR2/3/3A TR3 Hub Cap "Globe" Medallion
Scotsman
There appear to be two designs for the TR3 hubcap “globe” medallions. Are they both OE and if so on what model years do they correspond to? One of the designs has larger “Triumph” letters and fewer lines of latitude.
Geo Hahn
Okay -- looked at the TRA judging guidelines -- they cite TS13046 as the possible change point for going from 'enamel' to 'painted'. They note that is also the change point for disc brakes.
However, they acknowledge that some later cars also got enamel so 'make no deduction for either badge on post TS13046 cars'.
PeterK
Hope this helps. My 58 came with the center cap style without the Triumph underline and with Australia completely visible - another subtle difference. I don't think that any were painted back then.
S TR2/3/3A tr3 Jack, hub cap remover ect... Triumph 2
toysrrus TR2/3/3A Tr3 hub cap removal tool Triumph 24
J TR2/3/3A TR3 hub cap tool Triumph 14
K For Sale TR3 Hub...short studs Triumph Classifieds 0
T TR2/3/3A Hub Bearing Adjustment for TR3 w/Disc Brakes Triumph 3
B TR2/3/3A TR3 Front Hub Felt Seal questions Triumph 2
B TR2/3/3A TR3 hub removal Triumph 30
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
K TR2/3/3A Installing wheel studs to hub TR3 Triumph 2
Bremer TR2/3/3A TR3/4 fan hub extension elimination kit? Triumph 3
TRclassic3 TR2/3/3A TR3 fan pulley hub Triumph 3
mountainman TR2/3/3A Tr3 Fan Hub Triumph 1
B TR2/3/3A TR3 front bearing/hub advice needed Triumph 6
White79MGB TR2/3/3A TR3 Rear Hub rebuild continued Triumph 2
RedTR3 TR2/3/3A TR3 Rear Hub Rebuild, part 2 Triumph 4
RedTR3 TR2/3/3A TR3 Rear Hub Seal Triumph 7
D TR2/3/3A Free TR3 wheels, tires, hub caps Triumph 4
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
