TR6 TR 6 engine won't start
TulsaFred
73 TR6 project car
It's been sitting since 1987. In a garage until this past year then sitting in a field.
Compression 120-130 on all cylinders.
Static timing set at 12 degrees BTDC per manual.
Replaced coil with proper part ( had a resistance coil even though the ballast resistor is in place and functional).
Points gapped at .015.
Plugs cleaned and gapped at .025
Good spark.
Set valve lash at .010 on all valves.
Didn't do anything with the old carbs which will need rebuilt, but sprayed the venturis liberally with starter fluid to see if it would fire.
Nothing, nada, zilch, not even a hiccup. Drained the battery down,now on the charger.
Thoughts?
Thanks
Fred
Did you check for spark using one of the plugs still connected to its lead?
Are you sure the rotor is pointing to #1 cylinder when #1 is ready to fire (both valves closed) ?
I've had similar experiences with what they sell for "starting fluid" in CA these days. I would try carb cleaner instead, it burns better.
My guess is the timing is fubar or the rings are laying in the pan,...well maybe not that as you do have compression,though Isn't that a bit low?
I checked spark with plug connected to lead, I may pull them all and check them all like that (I only checked one).
I haven't had any problem with the starter fluid on my other cars.
I already checked timing using static method, both valves closed on Cylinder 1, pointer at 12 degrees BTDC, rotor pointing at number one plug wire.
The compression would seem to rule out rings or valves having major issues. It is slightly low, but within 10 lbs cylinder to cylinder.
Weird.
Fred
Found the culprit
The connections to the ballast resistor were crudded up and it was shorting intermittently
Cleaned up and it fires!
Now I need to drain the gas tank, rebuild the carbs and put in some fresh oil, then see how she runs
KVH General TR TR4A Engine Won't Start Triumph 34
D Engine won't start Triumph 14
M Wedge TR7 Won't Start When Engine is Warm... Triumph 4
R MGB-GT MGB GT won't start after engine is warmed up MG 3
R TR2/3/3A TR-3 engine won't start after rebuild Triumph 8
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
J Engine won't turn off TVR 3
PatGalvin The fun just won't stop [engine rebuild questions] Triumph 53
F 77' Midget engine won't stay on---- MG 7
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 0
R TR2/3/3A Engine revs up and down Triumph 7
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 21
L General Tech Engine id Triumph 9
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
