too rich ZS
Chicago
Member
Well have a nice headache right now from the clouds of blue smoke first start of the new year.
Had my ZS carbs rebuilt after a year of chronic lean condition thought they were getting leaky.
Now complete opposite problem. can't get em leaned out. Have them turned 2 complete turns CC still too rich. Sooty plugs and very rich exhaust.
Bugger... 70 TR6
Suggestions most welcome. need an asperin right now.
Hi.
I have just rebuilt my ZS, Im having the same prob?, I would be interested to know what might be happening, Mine are from a GT6 Mk3, CDSE as im told. But are on a Sports 6.
Thanks, Good luck Chicago.
Brian
Start by dropping your float level down a bit. Is your main jet needle centered in the main jet? Is there oil in your dampers? Thicken it up to slow down the slider a bit.
Ask the guy's who rebuilt the carb if they modified or ' repaired ' the main jets at all. Some people will still solder them up and re-drill them in an attempt to renew jets worn by an offset jet needle. That almost never works out.
Of all this I would say the float level drop has the best chance of helping.. If it's too high then too much fuel will be sucked up the main jet at any given throttle position..hence rich..
Good luck
no idea but I just got this book so I could lookup anything you might need.
Hi.
Thanks for the info , I have the ZS maunual, along with a Vit guide for the car, I will give it a shot on adjusting the needle, float.
Thanks
Before I pull em off to play with float level.
Want to make sure I've tried all the "simple stuff"
If I have it right, basic adjustments to start off with are low idle screw, needle height adjustment full CC for most lean, bypass valve full CC to seat, and trim screw again full CC for max lean position. There is one other spring loaded screw that I'm not sure what it does?
Anyway think I've tried all exterior tinkering still too rich, guess I'll try the float adjustment now. when it gets warmer again : )
I rebuilt my ZS carbs and had the same problem, too rich. The car smelled of gas with the top up, sooty plugs, etc. Nothing I did worked until I adjusted the float level. Very simple to do, if your careful you may not have to replace the gasket if its still fairly new. Unfortunately, the carbs heve to come off the car for this procedure, but if you previously rebuilt them, then you know how to do this already. To help me I used a micrometer from Harbor Freight Tools (cheap stuff but for this job, well worth the $6) to measure the 16mm clearance.
Thanks for all the excellent advice.
Dropped the floats to 17mm from about 15.
seems to have helped rear carb lightened up rear
plugs 4-6. Front still sooty, too cold out now.
found out the remaining spring loaded screw left side is summer winter adjust, didn't know that before. Will try some more tinkering when warms up a little.
OK, well very nice day to tinker. So lowered floats to 17mm rear carb better, front still too rich. Pulled again changed out jet seems to be better behaved maybe bad jet? Still working it out but done for today. Also installed pertronix EI one of the easiest mods I've done. Recommend to those who may be thinking about it.
B Triple carb setup too rich? How to adjust? Austin Healey 3
J TR2/3/3A TR3A is running too rich Triumph 4
M Too rich -- too lean Triumph 14
J TR2/3/3A TR3 Too Rich- What direction do I turn the nut? Triumph 3
floyd carbs too rich Triumph 18
H TR6 HS6 RUNNING TOO RICH ON TR6 Triumph 11
H Zenith Stromberg CD 175 Too rich Triumph 7
BigBird Idling too rich... MG 5
J I am Way Too Rich!!! Spridgets 12
B Midget that runs too rich Spridgets 6
Hamish Racing Harewood hill climb red flagged for being too fast …. Racing 2
J TR4/4A Exhaust a tad too loud... Triumph 6
jfarris Message too long error FORUM Navigation Questions 8
mctriumph TR2/3/3A The concept of too many Triumph 8
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
R For Sale Conundrum - Too Many Bugeyes Spridgets Classified 1
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
M TR6 76 TR6 Brakes too tight Triumph 10
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
M 1275 too high? Spridgets 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
JPSmit Pre-War Is it too early to write Santa? 1933 MG J1 MG 13
CJD General TR Too Rude Triumph 13
AUSMHLY 64 front end too high Austin Healey 14
S TR2/3/3A OMG problem—the doors are too tight Triumph 12
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
M Fat Feet hitting too many pedals Austin Healey 23
DrEntropy MGB Differential with too much lash MG 5
Got_All_4 TR6 TR6 engine rebuild. Too tight? Triumph 23
S TR2/3/3A New shocks too short? Triumph 7
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
HalLucy Post-War Other Renown - Idle too fast Triumph 5
TRMark TR4/4A Seal too large for Surrey backlight Triumph 8
J TR4/4A Too hot to drive a convertible Triumph 14
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
TomMull TR2/3/3A New Top Too Tight Triumph 14
K Too lean? Austin Healey 2
Jim_Gruber What Now, new gas tank filler neck is about 1/2-3/4" too short Spridgets 19
warwick-steve How low is too low? [spring question] Austin Healey 19
Marla TR4/4A Carbs too lean? Triumph 11
D TR4/4A flywheel bolts maybe too long Triumph 15
kennypinkerton MGB Are my wheels too far gone? MG 8
wkilleffer MGB Fitting a new top to a 74 MGB- how tight is too tight? MG 23
3798j Boomers Too Old for Sports Cars Other Cars 8
PC Dang, that was too good to be true... Restoration & Tools 3
tr3guy TR2/3/3A New Wheel Cylinder too large Triumph 7
A rear brake drum too tight after rebuild Austin Healey 3
