TR4/4A Tire options tr4a 60 spoke wheels 4.5 inch wide
Richard_Brown
I read and read and searched google several times and thought I would ask here as well. I know that its possible to still find soem off brand 165 15's but I have heard a slight larger tire will work fine as long as its not too wide.
what modern size will work well and look correct?
I think on a 5 inch wide wheel some people were going with 205's
what tire do you use ? brand and size?
thank you
TR4nut
For 4.5" rims I'd stick with 165's - 205s sound way too wide in my opinion. I've put 195s on 5.5 inch alloys, and even those tires stick out a little.
trrdster2000
Richard I put some 185-60's on your rim and not a bad fit, and fills the wheel well up.
I took the time to get a few results in Seattle.
https://www.discounttire.com/dtcs/searchTiresBySize.do?r=WASINT|c|Seattle&cs=185&ar=60&rd=15
Wayne
R
Richard_Brown
Wayne
Thanks Wayne, I was thinking this might be the best option to get into a better tire.
DNK
Richard, if you are an employee of the lazy "B". You get a discount at the Discount Tire
RJS
Gents,
Personally I would stick with 165/80-15 for purposes of original handling. Both Vredestein and Nexen make tires in this size. The 185s noted above would be good too.
Having said that, I've been riding on 205/70-15s installed by the PO 10 years ago. Yes, on 4.5 inch 60 spoke wire wheels. I know this is not recommended but have had no issues at all. If I have time tonight I will try to post pics.
But I absolutely plan to replace with 165s when it is time.
R
Richard_Brown
RJS said:
Gents,
thanks Bob, would be interested in seeing what those look like just to know how they fit the wheel well and look.
thank you
60TR3A
I have 5.5"-width Minilite replica wheels on my TR3A and 195/SR65/15 tires. I have an option to buy some used tires described as "165/15". Does anyone know if I can replace my existing Sumitomo tires with these period-correct, old tires w/o issues?
Geo Hahn
Since most people go to the wider alloys (among other reasons) to be able to mount wider tires I have no idea how narrow a tire you can safely use.
As for buying used tires -- you will want to check the date of manufacture on them to see how many years they have left (irrespective of wear).
BTW - I don't think 165/15 is 'period correct' for a TR3A... just the closest thing in modern sizing to what would have been on there 'back in the day'.
TR3driver
Great Pumpkin - R.I.P
Although Piggott doesn't mention it, I believe late (some time after 1959) TR3A were available with 165/15 Michelin X radials.
TR3driver
Richard_Brown said:
interesting, new search brought these up around $50 a tire for 165 15s
https://www.vulcantire.com/cgi-bin/tiresearch.cgi
That link didn't show any tires for me, so I'm not sure which ones you are talking about. But all the 165-15s I found on that site show "out of stock - no longer available".
TR3driver
Chart at https://www.turbinecar.com/tires.htm
says the width would be OK.
However, I wouldn't even consider putting on "old" tires! Even if they have never been used, the carcass (the inner part of the tire that holds it together) gets old with time, and can fail suddenly. On one of my Stags, the LR tire failed on the way home from the sellers house, and the belts not only flayed all the paint off the fender, but took away part of the fender itself!
Opinions vary on how old is "safe", but all the authorities (AFAIK) agree that 11 years is too old.
60TR3A
What do people with classic cars have on their cars if not old tires? I drive the car maybe up to 40 MPH, mostly 30 - 35, and rarely up to 55, but only to drive to the mechanic. As it is, my tires were probably put on the car circa 2000, so they are already 11 years old. Is everyone suggesting that I get rid of those tires and buy new? I can actually buy brand new Michelin XZX tires but at a hefty $189 each + freight.
Geo Hahn
61TR3A said:
...they are already 11 years old. Is everyone suggesting that I get rid of those tires and buy new?...
Don't know about everyone, but that is exactly what I think. I could bore for England with stories of too-old tires failing at awkward moments causing (in some cases) major damage.
61TR3A said:
... I can actually buy brand new Michelin XZX tires but at a hefty $189 each + freight.
Fortunately there are less pricey alternatives. All the more practical if you are not doing high-speed touring. Even then they can be fine -- I drove 1000+ miles in a couple of days, often cruising 70+, on the low-priced Nexens.
TR3driver
Personally, I use new tires :laugh:
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] I drive the car maybe up to 40 MPH, mostly 30 - 35, and rarely up to 55, but only to drive to the mechanic. [/QUOTE]
That probably does give you some leeway, as tires don't get nearly as hot at 55 as they do at the 75 or so that I usually drive. But it still seems like a risk to me. And I was only driving 55-60 when the tire on the Sports 6 let go (although it was probably a lot more than 10 years old).
swift6
Part of the cost of classic car ownership. If you want it to look original and be safe to drive. Less expensive tires are available if your more interested in driving the car for any real distance or at any real speed. Ninety-nine percent of the public would never know the difference.
TR3driver
DanB said:
Diameter of 165 radials is actually less than the original bias ply tires.
Unless of course the car came new with the optional 165 radials.
Frameman 1949 Tire Options Austin Healey 16
I TR2/3/3A TR3 tire options Triumph 9
B TR6 Question about tire size options on a TR6 Triumph 3
S TR2/3/3A Tire balance Triumph 15
J MGB Tire pressure for 1980 MGB MG 14
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Tire Age Austin Healey 14
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
T TR6 TR6 Tire Pressures Triumph 2
NutmegCT Tire pump in reverse? Restoration & Tools 5
prb51 BN6 Wheel/Tire Combo Austin Healey 26
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
F TR4/4A Tire saver ramp recommendations Triumph 10
D Wanted Austin healey Tire - used Austin Healey Classifieds 4
Bocaray TR2/3/3A Centred Tire Triumph 3
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
S For Sale Tire for Sale (155SR15) Triumph Classifieds 3
F TR2/3/3A Spare tire cover Triumph 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
Mark Bailey Old tire rule? Restoration & Tools 5
Healey Nut Tire Sizes Austin Healey 10
F TR2/3/3A Spare tire cover Triumph 3
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
K TR2/3/3A Tire pressure and ride comfort? Triumph 9
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
G Rear tire scrubbing!!? Spridgets 23
H Can a 175x13 tire be fitted on Bugeye Spridgets 6
M TR5/TR250 Compatible Modern Tire Size Triumph 5
L TR2/3/3A tire manufacturing build date Triumph 2
K TR2/3/3A Optimum Tire pressure for a TR3 daily driver? Triumph 5
J TR6 Tire Recommended for TR6 Triumph 3
S TR2/3/3A tr3 spare tire fit Triumph 16
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
L General TR tire age code Triumph 3
H TR2/3/3A Original Dunlop 5.50X15 Bias Ply Tire Data Triumph 4
AUSMHLY Wheel Tire Camber Austin Healey 57
madhouse Tire pressure monitoring system [TPMS] for Healey? Austin Healey 0
tahoe healey Tire pressure again Austin Healey 59
Raymond MGB Wire Wheel Tire Mounting MG 0
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
O TR2/3/3A Spare tire Triumph 4
M Brake fluid on tire - cylinder need replaced? Spridgets 19
F TR2/3/3A Spare Tire Size Triumph 11
H Tire choices for Bugeyes Spridgets 14
D Vredstein 185X70 Spare Tire Fitment Austin Healey 5
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
Darwin Spitfire Max tire width Triumph 4
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
