Stromberg 175 cd question
Larrym
I am looking for anyone theat can answer questions about the older Stromberg carburetors (non polution type)
Larrym
Post yer questions and mebbe someone can answer 'em.
I recently baught two 175 cd carbs and the lower main jet adjusting screws are missing. I can ont find any in the free world, so decided to make them, but need to see one to get the dimensions. I do not knuw what they look like. These are for the pre polution carbs.
Larrym
I've got two but they are sorta busy right now.
You might try posting on the Triumph forum as these are the carbs on the late TR4s.
Larry-If you are still looking for the parts or dimensions, contact me. btp44:ataol.com
Berry
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
R Zenith Stromberg CD 175 float replacements? Triumph 3
M stromberg 175 cd? Triumph 5
M stromberg 175 choke cable? Triumph 2
M zenith stromberg 175 cd Triumph 24
M zenith stromberg 175 cd. Triumph 7
H Zenith Stromberg CD 175 Too rich Triumph 7
Brooklands Air Filter for Stromberg 175's Triumph 3
E Stromberg 175 idle Triumph 2
H stromberg 175 carbs Jaguar 1
A TR6 Stromberg CD2 Air Cleaner Covers Triumph 3
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
Celtic 77 MGB 77 Stromberg issues MG 12
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
S TR6 Stromberg Bypass Valves - Question Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
M General MG stromberg carb MG 5
Sarastro TR4/4A Stromberg linkage question Triumph 4
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D Stromberg Dash Pot Screws Jaguar 3
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
steveg Online SU and Stromberg needle database with comparison charting Austin Healey 2
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
R GT6 Carb Floats for Stromberg 150 . Triumph 5
bfitz Zenith Stromberg O ring question Other British Cars 8
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
K TR4/4A Stromberg question. Triumph 13
M TR4/4A Stromberg CD175carb query Triumph 7
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
M TR4/4A Stromberg ? Triumph 4
L zenith-stromberg carbs Lotus 11
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
G Stromberg cd150 question Spridgets 1
TR6BobNF General Tech Midget Stromberg 150 Adjustment MG 8
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Weber/stromberg air cleaners Jaguar 3
dklawson Early Stromberg Floats - 150CD Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
W Zenith stromberg carbs Jaguar 3
J stromberg float source or x referance Triumph 2
D TR6 76 TR6 Stromberg Air Valve Triumph 2
