Stock oil filter vs spin on filter
dvu101
Each time I change oil with my stock filter I think about switching to the spin on filter.
But...
Several times I have asked around and have been talked out of switching.
I have been told the spin on does not clean the oil as well.
Is this true? Is there anything to worry about?
It seems to me that I would be more willing to change oil more often it was not so messy.
Any thought or suggestions?
If I switch, which spin on is best?
Thanks Scott
I don't know which is best, but I have heard from more than one person about having leaking issues with the housing or housing seal when changing to a spin on filter.
The cannister filters are certainly a bit more fiddly, but you can adapt and get used to them with perserverance.
Consider that most modern vehicles--with tighter clearances than a Healey engine--use spin-on filters (although I've heard some engines now use a cartridge-type, for economical and environmental reasons).
The canister type can use either corrugated paper or fiber--wound cotton gauze, from the looks of it--cartridges. I would expect the paper type to be about the same, or possibly less, effective at filtering than a modern spin-on filter. Conceivably the fiber cartridges filter better than paper, but as long as the remaining particles are smaller than bearing clearances it doesn't much matter. At some point you can have too much filtering, either decreasing flow or triggering the bypass mechanism anyway.
I have a spin-on in my BJ8. It's the machined disk type, just a plain adapter between the block and the filter. It came with 2 Allen-head bolts and a gasket; I installed it and it hasn't leaked a drop in approx. 20 years/100K miles (can't say that for the rest of the engine). I've never regretted installing it, and the original canister filter sits in a drawer should I ever need to sell the car.
Like Bob, I have the spin-on type that I purchased from Moss (?) several years ago. It has worked just fine. I use a Fram Tough Guard filter, but I don't recall the number off the top of my head.
A properly made adapter and quality spin on filter will outperform an original filter hands down. The spin on has a anti drainback valve which goes a long way to preventing dry starts. Dry starting is where most bearing wear occurs so fitting a modern filter will add many years to the useful life of the engine.
The original filter housing has a bypass valve that sticks open and allows unfiltered oil to the bearings. It is there to ensure some oil gets to the bearings if the filter becomes completely clogged but after many years it gets carbon stuck in the seat and it leaks. I would not start an engine with an original filter unless I knew this valve was functioning correctly. It trashed the bearings on my engine after only 2000 miles because the PO didn't have it cleaned during a full overhaul.
I didn't like the look of the available spin on filters so opted to make my own adapter to fit inside the original housing so it still looks stock.
Andy.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]It seems to me that I would be more willing to change oil more often it was not so messy.[/QUOTE]
Scott, not the first time I've heard that (nor said to myself :wall: :hammer: :devilgrin:
And somewhere around 30ish years ago I was at a show/swap-meet and as a pal and I checked out the swap meet we ran across a couple of COMPLETE, from block out, filter assemblys. PURCHASED in a HEART BEAT ! ! ! :smile:
Haven't done an "on car" filter change since ! ! ! :laugh:
That even includes Customer Cars and there have been a couple go out the door with what I believe to be the closest to Factory Engine Colour matched with some serious UGLY & MIS-matching coloured motors ! ! :devilgrin: :cooler: :lol:
Cheers............
:cheers:
Ed
Hey Scott,
Like others have said, used a spin on filter and adapter on several Healey's through the years and never had a problem. Just make sure you have everything lined up properly with the gasket and holes when you install it. If you mess up the gasket you can buy another one, just use the standard gasket that fits the original filter assembly as it mounts to the block. I painted mine Healey engine green, both adapter and the filter so doesn't stick out as much as not being original.
Regards,
Mike
Spin-on filter. I tend to use the Fram HP-1 hilter, though the way mine is mounted on a remote base and hanging downward, it doesn't need the anti-drainback feature. This allows the filter to be saturated and filled with oil when I put it on, eliminating the engine run time required to fill up the filter before getting pressure.
Nobody would mistake (or be fooled) that my oil plumbing is standard, with the remote filter, oil cooler, thermostat/bypass and engine block adapter, but I do like the idea of painting them green__just never thought of it!
This topic comes up from time to time, here on the BCF. If you do a search you'll find many posts about it, including which spin on filter is best too. One of the highly recommended filters is the K&N 2009 filter. It incorporates the anti-drainback feature. There's more to a filter than just anti-drainback, and that was discussed in one of the posts. The write up was good, so I use that one now. It's canister is larger than most of the other filters, so there isn't as much wiggle room getting it in and out. Not a problem, just pointing that out.
Lin said:
Hey Andy,
Got a photo?
Lin
Hi Lin,
I only have a couple of pics from when I was testing it on an old sedan engine. The bowl is held on by a magnet stuck on the back of the filter but it doesn't stick on quite as strongly as I had hoped so I may do another version with a thread on the ali adapter to hold the bowl on.
All the dyno tests I did a few months back were with this setup and it worked very well with instant oil pressure at cold start even on the old sedan engine.
Andy.
:iagree:
I like the K&N 2009 filter also, because it has a "NUT" on the end which really makes it easy to remove and tighten.
:yesnod:
Thanks for the info guys. I never thought of a lot of the info I learned.
brgrmyster GT6 Proper stock color oil filter canister 68 GT6? Triumph 7
I oil/oil additives for stock Bugeye engine? Spridgets 10
D Stock Camshaft TVR 0
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
nichola TR6 Stock exhaust sound... short video Triumph 4
Joel Lester TR2/3/3A Are all "stock" camshafts the same? Triumph 9
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
S TR2/3/3A stock fog light Triumph 2
PC Actually in stock? Spotted 0
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
R Upgraded rod bolts for stock rods Austin Healey 1
S New Build Stock Wheels? Spridgets 38
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
B Wanted stock Bj8 distributor Austin Healey Classifieds 1
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
simon1966 Rarity of Stock 100! :-] Austin Healey 13
T Front Tilt or Stock Fit Bonnet Spridgets 18
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
T Tilting the stock seat for comfort Spridgets 6
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T WW Axles in stock Bugeye housing? Spridgets 7
L Modifying stock shift surround for Datsun 5 speed Spridgets 20
K TR4/4A Stock Triumph Radio Troubleshooting? Triumph 4
C Smaller diameter steering wheel - that looks like stock? Austin Healey 16
G TR6 TR6 air filter element replacements for stock housing Triumph 3
CJD TR2/3/3A Stock Valve Lift Triumph 3
RJS TR4/4A TR4A Stock Ride Height - my measurements Triumph 0
CJD General TR BSW thread stock Triumph 2
T TR4/4A Flywheel... Lightened or Stock, that is the question Triumph 14
RJS TR4/4A TR4A Stock Ride Height Triumph 5
Gerard Anybody have a steering wheel emblem for '68 Sprite stock steering wheel? Spridgets 11
Jim_Gruber Tire Size and Stock BE Wheels Spridgets 40
K TR2/3/3A Lightening a stock TR3A flywheel..... Triumph 13
M Healey Mk2 with Colored stock steering Wheel Austin Healey 3
B Found more unopened stock to ofer/trade/giveaway to a good home Spridgets 0
C Stock seat belt color? Austin Healey 11
K Converting a MkII with a V8 back to stock Jag 6? Jaguar 3
Ed_K Modifing the stock BJ8 air cleaners Austin Healey 0
T TR2/3/3A Attaching HS6s to the stock TR3 manifold. Triumph 3
R Planing my built. Stock vs transplant Spridgets 58
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
T stock bugeye front springs Spridgets 4
T Milling a head on a Stock 1275 for compression? Spridgets 13
