TR5/TR250 Starting a TR250 that's been sitting for 10 years
angelfj1
My TR250 has been sitting in an unheated garage for nearly 10 years. I would appreciate recommendations for getting it ready for the road this summer.
Thanks, Frank
Nice car!
In terms of getting it roadworthy, I would think you need to go through all the systems, one by one: brakes, fuel, spark, clutch, oil, ...
Flush and replace all fluids. Check flexible hoses for cracks. Check rubber bits in the suspension for the same. Tires probably need replacing after 10 years.
Is motor frozen? Was it put away "wet", or properly stored for the long term? (E.g. squirting oil into cylinders, draining fuel, etc.)?
It might be best to reach out to your local Triumph club. Offer a few cold brews and brats, and have someone look it over.
1. Clean fuel line from tank to carbs.
2. Check condition of tune.
3. Check brake and hydralic lines, renew fluids.
4. Lube chassis
5.Renew all oils and fluids.
6.Renew coolants and belts.
7. Start
8. Clean car thoroughly.
9. Recheck fluids, and Restart
10. Drive slowly around block
11. If all seems well, wax and drive more.
Don't be surprised if the carbs overflow or flood the engine combustion chambers....the float chamber needle valves might be stuck open...
If it happens, I can post a non-evasive procedure that might clear things up...Just let us know.
Tony was thorough, mine is short, but you get the drift
All good advice above, I have found when my TR250 sits too long the clutch sticks--the other stuff, fluids and hoses first, but be careful first time you try to start it--if you are in gear and the clutch is stuck it will roll forward on the starter.
I have always pulled the spark plugs and put oil in the cylinders on top of the pistons and rings. I am a bit of a worrier and want to make sure I have good lubrication before I turn the engine over and eventually have oil pressure. Over the years, I have used different lubricants like Marvel Mystery Oil or a penetrating oil followed by regular motor oil. Everything mentioned is good and again very thorough.
Marvel Mystery Oil is "The Elixer of Life" for the job. đź‘Ť
Uncle Tony proved that wrong, white vinegar or weezel pee (1/2 trans fluid, 1/2 acetone), working for me now in my GT6 that sat for 42 yrs. Someone on this site suggested it years age, has worked for me since. Tony had it as 1st, wp 2nd as it took less to free up rings and actually took off the rust. An addition, my brother in law being an A&P engineer used Marvel Mystery Oil in his Opel GT for oil and only changed the filter and added more MMO, survived 190,000 miles until the suspension rusted off.
It was likely me who originally suggested the weasel pi$$ back then. The Marvel has plenty of lubricity and Frank is in eastern PA where humidity is likely less a problem. If it sits for a bit, it should be about as effective, methinks. It was a "do no harm" first suggestion.
Very true Doc. Never tried Marvel, but do like how the weazel p ignites with heat.
I will admit Marvel makes more smoke than fire! :LOL:
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
K TR2/3/3A Re-starting a warmed up motor? Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 22
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
mgedit TR2/3/3A 56 TR3 Starting Issue Triumph 9
M Starting from cold Austin Healey 2
R Very Difficult cold weather starting problems! Austin Healey 21
R TR4/4A Starting TR4A after 30 years Triumph 12
R winter hard starting BJ7 Austin Healey 16
P Jump starting a positive ground BJ8 Austin Healey 4
W starting motor Jaguar 0
D TR2/3/3A Starting my Bodywork journey. Triumph 166
P TR6 Quick starting Triumph 2
Joe Reed General Tech Starting a screw in a tight location... MG 9
P TR6 TR6 hard starting Triumph 24
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
stretchit2 Starting Issue Austin Healey 6
M TR6 Intermittant starting problems Triumph 4
Willie_P TR4/4A Starting long dormant TR engine..start up procedures? Triumph 10
S Hard starting on Webers from cold Austin Healey 12
T TR4/4A Restarting an engine - oil pressure problem Triumph 6
