TR2/3/3A Starter/ring gear engagement
Jim_Stevens
Hi-
Still having problems with starting. All grounds re-checked, solenoid replaced. Starter motor turns but crankshaft only a tad, if at all. I had thought that the starter pinion is normally retracted from ring gear, and that upon current, it flies forward to engage, then retreats when started. (Retired military… hence the terms…!).
However, look at the picture, taken from underneath the bell housing. Looks to me like when the current hits, the pinion flies forward, mostly missing the ring gear. WOSP gear reduction starter, number of teeth correct. I have a buddy coming over in the morning to push the start button while I observe from underneath. (Car on ramps, not jack stands). What am I not getting? Jim
Jim Stevens
TS44067L”O”
Hi-
Jim Stevens
TS44067L”O”
Jim, can you give us a background?
Has this set up run before?
Which starter and which ring gear do you have?
Charley
I am still a bit confused...is the pinion hitting and then locking up solid, or does it spin without doing anything?
Hi-
Jim Stevens
TS44067L”O”
If I am understanding your post, the starter is spinning but missing the ring gear.... correct?
If this is what's happening, I had a similar problem on my TR6. A new gear reduction starter would spin but not engage the ring gear. It turned out that the ring gear had moved quite a bit off of the flywheel.
The photo on the left shows how much the ring gear moved off of the shoulder of the flywheel (red arrow).
The photo on the right is after I installed a new ring gear... the gear now sits against the flywheel shoulder.
Thanks all. I’m waiting for a buddy to come over so I can get under the car while starting.
To recap: Symptoms are the starter motor turns but the crankshaft turns weakly or not at all. Previously, this had been only after a spirited run fully warming up the engine, but now it’s all the time. This started after the body restoration, during which the engine sat. A previous gear-reduction starter worked fine before the restoration.
Because of the fresh paint and hot engine conditions, I thought that it was a grounding issue, but I’m running a strap from the battery to the block (scraped clean). The starter motor flange on the block was also cleaned. Starter motor and exhaust pipe were wrapped. Also just yesterday I tried a very high current battery, thinking I had a weak battery. So I’ve exhausted all the electrical possibilities.
Now the working theory is ring gear engagement, hence the look through the bell housing. As I wrote yesterday, I was surprised to see the pinion already in “meshed“ position. And I noticed a misstatement in my description, since the starter faces aft, the pinion is thrown aft upon current flow.
I’m actually encouraged by Elliott’s photo— maybe we’re homing in on it? More after we crank it with me underneath. Jim
Studying Elliot‘s photo compared to mine from the inspection port, my ring gear is flush with the after-edge of the flywheel, i.e., if the two flywheels were similar, the little red arrow on mine is even longer than his.
You may have found the problem.
Rotate the engine so you can see more sections of the ring gear.
That was it indeed! The ring gear is spinning like mad on the flywheel. That only took six months… oh, well. Experience is the best teacher. Off to buy a ring gear, and maybe a flywheel too. Thanks all
Jim Stevens
TS 44067L”O”
Jim Stevens
TS 44067L”O”
It drove me crazy too! I rebuilt my original starter first then bought a new gear reduction starter all with the same results.... starter spun but engine didn’t.
Ring gear was cheap but pulling the transmission was a PITA. Get her done!
Yes I was awestruck the first time I installed a ring gear with the shrink to fit on the flywheel. I put the flywheel in the freezer and ring gear in the hot water and the ring gear slid on then shrunk tight. I wonder if those new starters have too much torque at the beginning for the shrink to fit ring gears. I am looking for an older flywheel if you go new.
steve
If you have the older bomb nosed starter, is sounds like your rubber isolator has shredded...a common problem with those starters. Since it is a gear drive, there is no other way the starter could turn fast and the flywheel not turn at the same relative speed without a whole lotta grinding. They call the part a "sleeve" in the moss starter breakdown...item 46
steve
The more I think about it, the more I agree with you.
Gliderman8 TR6 Starter not engaging into ring gear Triumph 32
R BJ7 Gear reduction starter and starter ring gear orientation Austin Healey 17
Kleykamp TR2/3/3A TR3 Starter nose broke off, ring gear,lots of ??? Triumph 6
MTribe gear reduction starter fix ring gear bevel? Triumph 5
J starter and ring gear Triumph 14
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
