TR6 Starter finally cranks...then CRACK. Vicky Brit parts order time.
sammyb
Got the starter connected correctly and amazing how it now works. Moment of truth: I turn the key and it cranks momentarily. I check to make sure everything looks good. Turn the key again and it cranks for a second then CRACK. (Yes from CLICK from a dead starter to CRACK as the...)
Rearmost rocker arm breaks in half.
I was having trouble with installing the pushrod -- it wouldn't sit right. Finally it settled in, but evidently not enough.
So I guess it's another order from Vicky Brit, as I'm in need of a new rocker arm...probably a new pushrod too. (Might as well get two in case another is wobbly.)
Gotta love working on old cars.
More important, why did it break? Do you think the pushrod wasn't in down in the lifter, thus pushing the valve into the piston? Were the clearances adjusted?
I agree with Darrell, figure out why it broke, you certainly don't want to do it again. From what you say you might not have had it seated right, which is possible, but although a little hard to describe, it isn't too hard to tell when the little ball is seated in the lifter and the cupped end mated with the rocker. I think a problem in that area would be pretty apparent when you adjusted the valves. Other possible causes, stuck valve? high lift cam and binding valve springs?
The answer is "I don't know". The head just came back from the machine shop with a clean bill of health.
I stupidly didn't adjust the valves thinking that I could just take off the rocker shaft, remove the head, get the stuck spark plug removed, put everything back on and fire it up. The interesting thing is that the machine shop didn't mill the head, but it has the symptom others have had of that last pushrod acting too high like the head was milled. It all fit perfectly prior to removal, though.
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
John_Mc TR6 Starter not engaging consistently Triumph 9
R TR2/3/3A Starter rear plate 54 TR-2 Triumph 12
M TR6 Starter lagging issue Triumph 2
Gliderman8 Starter keeps running TVR 20
