MGB Starter and fuel issue
gudfood
My 79 B was down all last year with a clutch fluid issue (still in progress). Went to start up this year with a new battery and starter was operating intermittently/randomly. (I Cycle the key until starter decides to activate). Also discovered that I have no fuel flowing at the carb after 3 years of starting up right away in the spring. Are these two issues possibly related? Ideas on where to start troubleshooting?
dklawson
The two problems are probably only related because the car sat for a while.
When you turn the key to the run position can you hear the fuel pump running or is there silence?
For the starter, a '79 would have a starter relay in addition to the solenoid on the starter motor. When you turn the key to the start position do you hear a soft click from the starter relay energizing? Do you hear a louder click from the solenoid energizing?
Have you measured the battery voltage yet?
G
gudfood
Thanks Doug. The battery is brand new. I am going to have to disconnect the fan so I can hear what is happening when I turn the key. I installed a new relay and it did not help
dklawson
If you need a wiring diagram for your car, copy the PDF linked below. The later model MGBs are covered on the last couple of pages.
http://www.advanceautowire.com/mgb.pdf
When trying to start the car do you have any status lights on the dashboard?
Which fan is making noise? Is it a shop fan or the cooling fans on the car?
The car's cooling fans should not run when the key is turned to run unless the temperature switch is closed. Since your engine isn't running (and therefore not hot) the cooling fans should not be running.
The following is just a quick overview of what should happen.
You turn the key to the START position. The white/red wire on the ignition switch should have 12V on it.
When the white/red wire has 12V on it, the starter relay should close with a soft click.
When the starter relay closes, the starter relay should supply 12V to the white/brown wire going to the starter motor solenoid.
When the white/brown wire has 12V on it, the solenoid on the starter motor should fire with a loud click.
Then the starter motor should spin the engine.
With the help of an assistant (and a multimeter) you can measure where and if you have 12V on the starter circuit. You'll want to measure between ground the the white/red wire and then ground and the white/brown wire.
G
gudfood
Thanks again Doug! Starter is functioning today. Tested connection at starter, in the trunk/boot and I have power to the pump. The cooling fan is wired for constant run, not off of the radiator switch. Might convert to a belt driven fan? Disconnected the electric connection for now so I could hear what's going on
dklawson
I'm glad things are working today. Do you think just probing around got an electrical connection working? Maybe there are some connections that need a bit of additional cleaning and a light coat of dielectric grease during reassembly as a bit of protection.
It's your car so it is your decision if you want the fans on all the time. You can always wire in the factory switch later if you want to. If you want an adjustable switch, the company Derale makes one with an expansion bulb/sensor. Mounting the sensor can take a bit of creativity. I have one on our GT6 and the sensor is secured to the radiator header tank. The Derale products are sold by places like Summit Racing. However, other vendors probably sell the same kit for less.
https://derale.com/product-footer/electric-fans/fan-controllers/adjustable-controllers/16769-detail
G
gudfood
The car has a switch plug mounted in the radiator and a spot for another fan. Might look into this other one you shared?
Thanks,
Marty
R Fuel at Start Up & starter fluid Triumph 17
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
John_Mc TR6 Starter not engaging consistently Triumph 9
R TR2/3/3A Starter rear plate 54 TR-2 Triumph 12
M TR6 Starter lagging issue Triumph 2
