Spitfire Spitfire stereo question
Jerseygirl
Forgive me if these are stupid questions, but I'm still awaiting the arrival of the owner's manual I ordered so...
My Spit came with a Sanyo AM/FM/Cassette head unit and two front Sanyo speakers tucked in behind the dash. Both the head unit and speakers are ancient. Could these be the original equipment? Were stereos even a factory option, or was it a dealer install like in my Volvo? Did cassette decks exist in 1979?
Also, if the stereo was a dealer install option, were they standardized as far as speaker locations? I know in the Volvo there are various locations that the dealers would place the speakers (and antennas for that matter). I ask because I'd like to keep the car as stock as possible, but at the same time I'm very tempted to maybe install some rear speakers. I hate the idea of cutting holes in the interior of the car (if there's even room) but if the dealers did the installs and they placed speakers in various locations, I wouldn't feel so bad about adding a couple speakers.
I've got a basic Kenwood MP3 head unit that I had planned to put in the Swede but have since changed my mind. Looks like it would fit right into the spot where the Sanyo is now.
Thanks in advance for any info. I promise to ask fewer stupid questions once I get an owner's manual and shop manual. /ubbthreads/images/graemlins/smile.gif
Hey Robyn,
No such thing as a stupid question - I should know since I've asked so many I thought were stupid!
1. My understanding is that the cars were shipped without radios to prevent theft, then installed at the dealer.
2. The Sanyo is most probably not original equipment.
3. Yes Virginia, they had cassette decks in 1979.
4. You won't be able to mount speaker in the back unless they're surface mount - the gas tanks right behind the rear panel.
Pretty much any "sound system" in a Triumph was a dealer install in the US. I don't think Sanyo was normally one of the suppliers of "factory" (actually a bit more like "factory-approved" or "distributor approved") units, but I do remember that one of my local Triumph dealers had a display with a number of different possible radios.
Yes, cassettes were around then!
Bottom line: what you have likely is not "original" but possibly does date to when the car was new or nearly so!
Unlike Volvo, there really wasn't much of a "standard" location for speakers in the Spitfire. As far as additional speakers are concerned, especially rear speakers, it's more a matter of a: personal preference and b: wherever there's room to fit a speaker. I've seen a number of Spitfires with some manner of speakers on the rear floor as well as speakers let into upholstery panels (if there's room behind).
Oh, one other thing: the only stupid questions are ones you DON'T ask (and kick yourself later for NOT asking them)!
Ah... Well that solves the problem of installing rear speakers then. I knew the gas tank was back there but wasn't sure if there was any room. Not interested in surface mounting speakers so I'll just be happy with the two I have now. I kind of thought the Sanyo might not be the original stereo. Now I won't feel bad about pulling it out. /ubbthreads/images/graemlins/grin.gif
Thanks!
You can easily have good sound, and only need a little woodworking skills. I made speaker boxes with a quarter sheet of 1/4" masonite, quarter round molding, and short pieces of 3'4" pvc piping which lie on the back shelf. Cut masonite to make boxes 9x8x3. Cut moulding to be used as corner supports. Hot glue & tack sides & bottom. Line w/jute rug padding. Cut top for 6 1/2" Sony 4-way speaker - Walmart $50 and good sound. Drill top for short piece of pvc tube to be hot glued in and used as a bass tube. Hot glue onto box. Contact cement rug/material of your choice to cover box. Install speaker. Wire w/quick disconnect plugs for removal if space is needed/theft deterrent. Sounds great. I believe originally the front speakers were mounted in the outer corners of shelves at a 45 degree angle. Same black cardboard as the shelf w/3"-4" speaker. I made kidney pads for the TR6, maybe it can work in the Spit too. Just haven't measured yet. Still playing with the new toy.
Steve
Good to know for future reference, but that's probably a bit more involved than we want to get at the moment. Right now I'll be happy to get a new head unit in and maybe replace the two existing speakers. /ubbthreads/images/graemlins/grin.gif
Jerseygirl (Robyn), it is nice to find a lady that is interested in, and works on, Little British Cars. Keep up the postings. You are only about two gazillion posts behind Jaybird (Janel) over in the MG section! Good luck with your Spit.
Bill
Hi Robyn and welcome!
I mounted two 5" slimline speakers in the rear panel of my Spit6. There is an openning for the speaker magnet at the bottom rounded corners of the gas tank. I don't remember the depth of the speakers I used, but it had to be around 2 to 2 1/2 inches. With some careful measuring you can get them to fit in the openning. Just for some added clearance, I added a strip of heavy foam 1/2" thick to the gas tank and along the bottom edge of the board. I attached a photo.
[ QUOTE ]
[/ QUOTE ]
Thanks! I have become obsessed with this car in just a few days. Can't believe how much fun it is. I'm very happy I made the impulsive decision to buy one. /ubbthreads/images/graemlins/wink.gif
Hmmm.. Now that picture has me thinking about rear speakers again. But I think I'm getting in over my head for the moment. Really need to get the other car back in one piece before we start tearing another one apart. /ubbthreads/images/graemlins/yesnod.gif
And I just emailed British Miles over in Morrisville, PA to see if they have a spare rim and/or mirror mounting bracket. I'm really psyched to know there is a source for parts and service less than half an hour from my house. Woohoo!!
Robyn, you can get speakers in molded plastic housings and place them on the floor behind the seats. They're easily removed for shows if you want to stress originality and you're not cutting holes in panels.
Bob
Hey, I can finally answer a question about something I know about! I was selling home and car audio in 1979, and one of our lines was Sanyo. They were OEM suppliers for Sony car audio cassette deck transports, as well, and generally regarded as pretty good quality. So, it is possible that it's an original radio! Of course, nothing could touch the Concord HPL-100 I had in my '70 Datsun 2000 Roadster. Now, that was a radio!
Best, Kevin Browne
'59 TR3A #58370
Hmm... I just realized I have an old speaker box that might fit... We'll have this car pumping out serious tunes in no time. /ubbthreads/images/graemlins/wink.gif /ubbthreads/images/graemlins/cheers.gif
/ubbthreads/images/graemlins/tongue.gifFor rear speakers, do what I did with mine. Mount them in $9 Walley World boxes. Heck, you can even use WW speakers as well.(did this recently to my Vette) Sound really good for the $$$. Don't surface mount anything in back, it won't sound as good as a box. Just my $0.02...
Be carefull mounting speaker boxes in the rear. They become lethal projectiles upon a (Lord forbid) front-end collision.
Bill
[ QUOTE ]
Bill
[/ QUOTE ]
Hmm... good point. We'll have to figure out some sort of descreet mounting system.
It looks like my speaker box will fit. Take up most of the space behind the seats, but hearing the music over wind noise should not be a problem. We're having dreams of classical music blaring as we cruise down twisty back roads... /ubbthreads/images/graemlins/yesnod.gif
The box is grey, however, so it may get recovered in a closer matching carpet once Robyn gets past how huge it is. /ubbthreads/images/graemlins/tongue.gif
[ QUOTE ]
[/ QUOTE ]
Well, I haven't seen this box yet but if it's THAT big, I can do without rear speakers...
One of the things that I got from the VW people is the creation of a speaker deck that also serves as a closed storage area. It works nicely for both! For my VW as well as my TR3, I built a simple frame that goes across the rear deck, about 6-8 inches above the original. On that I put a vinyl-covered speaker panel with speakers on left and right ends and a vinyl covered, hinged trap door in the middle to store stuff out of sight. You can put hats, gloves, packages, CD's or whatever in there out of sight but with easy access. I don't anchor the panel/frame because the weight of the speakers and panel holds it in place nicely and allows me to disconnect the speakers and pull it out if I need to. Did another deck version with a simple portable CD/am/fm player mounted on top so it could be taken with me to events/camping trips, etc.
[ QUOTE ]
Hmmm... now that ideas sounds VERY interesting!! /ubbthreads/images/graemlins/thumbsup.gif
[/ QUOTE ]
Translation: I'm taking my speaker box home.
But, yeah, a couple of 3-way 6x9's mounted in a deck should put out decent enough sound for our tastes. Thanks for the tip. Yet another project I could use a band-saw for... /ubbthreads/images/graemlins/smirk.gif
[ QUOTE ]
[ QUOTE ]
Hmmm... Yet another project I could use a band-saw for... /ubbthreads/images/graemlins/smirk.gif
[/ QUOTE ]
Yeah-- I've had one for about 30 years-- use it far more than the table saw.
J TR4/4A 1977 Spitfire motor/trans in a '64/5 Spitfire Triumph 0
J Spitfire spitfire Triumph 2
C Wanted Spitfire 1500 diff rebuild Triumph Classifieds 0
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
