Spitfire Spitfire clutch problem
TR_JOE250
So here is the story, I put a three piece kit in my 73 about 5000 miles ago and it was working great. I recently replaced the master and slave cylinders with new repro units, flushed the system, filled with dot 4 fluid and bled. The problem is now I have very little pedal and can't get it into reverse while running and first is a chore as well. There was some play at the pedal from ovaling of the hole but I took care of that. I am at a loss and would appreciate any advice that anyone has to offer. FYI slave and master were shot and all parts came from Spitbits. Thanks.
71MKIV
sounds like there is still air in the system. IIRC the bleed screw is on the bottom, making it a chore to properly bleed the air out of the clutch. I machined a slot on the other side of the slave so the bleed screw was on the top.
Andrew Mace
Steve, you're correct that the bleed screw should be at the top. Both holes in the slave cylinder should be the same, so it shouldn't require any modification of the cylinder body to put bleed screw and connecting pipe in their "proper" positions.
BRSLimited
One trick that I use on these that are a pain to bleed is to use a clean oil can (only for brake fluid)and fill it from the bleed screw until the master cylinder is full. Also works for brakes.
TR_JOE250
TR_JOE250
Thanks for the input guys, but I dont believe there is air in the system, clean fluid throughout and bled several times, no air bubbles. Is there any chance that I have defective/bad parts?
Andrew Mace
TR_JOE250 said:
The problem is now I have very little pedal...
By this, do you mean there is limited travel, or that there is only a small part of that travel where it feels as if the pedal is doing something to push fluid? It's possible that the pivot pin for the throwout bearing arm is on its way out or gone. Not too difficult to check, as it's kinda visible from under the hood (RH side of the bellhousing).
Or, yes, the new hydraulics could be faulty...or even the pressure plate or driven disc, but that seems somewhat unlikely.
DougF
Did you have a full pedal since and lose it, or has the pedal been weak since the new parts?
71MKIV
Yea, why did the parts get replaced?
assuming that the new parts never worked is the air in the system,
worked then didn't might be the pivot pin fell out, or thrust washer
rikiwho123
hey joe had the same problem when i changed my clutch system and thought i had all the air out ; i let it sit a couple of days went back rebled it and it works great ; now a firm petal so good luck.rick.
billspit
I had a lot of trouble bleeding all the air out of my clutch year ago. I ended up removing the slave cylinder from the transmsision because it was tilted down such that air was trapped inside the slave. Bled it, bolted back up and Voila!
bigjones
I heard of a "trick" whereby you wedge the clutch pedal down and take off the master cylinder cap. Then leave overnight.
Never had the need to try it - just saying.
Cheers!
TR_JOE250
TR_JOE250
Thanks for all the input guys. I'm going to take another look at everything and bleed system again after I remove the trans tunnel. I've found it's much easier and had more success this way.
TR3driver
Great Pumpkin - R.I.P
If you feel adventuresome, Joe, you might try my favorite trick : Pump the pedal up as much as you can, then hold it on the floor for a count of 10. Release it entirely and count 10 again. Repeat the sequence 2 or 3 more times, then take a test drive. I've not tried it on a Spit, but it works great on my Stag & TR, no bleeding required.
TR_JOE250
TR_JOE250
Well I checked the system over again and bled again several times, no air but it didn't help. I rebuilt the original master, no help. I'm wondering if the slave is a bad component. As I recall now I got it from Napa and it was more than likely made in China. The original was leaking quite a bit, why I replaced it, as was the master. I took apart the old slave. It looks like it only has one seal. Any other ideas guys? I don't relish the idea of pulling the trans but I'm at a loss.
Andrew Mace
How does the pedal feel? "Typical" clutch pedal resistance, or does it just flop down and back up? Does it get any better with rapid pumping? Do you see any bubbles in the clutch master when you pump the pedal?
Oh, and did you check to see if the throwout bearing arm pivot is still in place?
HerronScott
I'm with Andy and would like to understand what little pedal means.
Scott
Rhodyspit75
This is the pin Andrew is talking about.(arrow) They can wear or fall out and give you the same symptoms as air bad hydraulics.
TR_JOE250
TR_JOE250
Can someone help me out here and tell me what I'm looking at and where here?
Bob Claffie
Possibly all wet but the last time I saw one of those was in the 1970's so--- If I remember wrong cut me some slack. ( The real answer will be here soon). That pin is on the PS side of the bell hsg and is the pivot for the T.O. bearing arm. Bob
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
dklawson Spitfire Clutch Kit Preference - 1500 Spitfire Triumph 3
STL_Joe Spitfire Spitfire MK I Clutch Triumph 4
NamVet Spitfire Spitfire clutch Triumph 4
J Spitfire Spitfire Clutch Help Triumph 14
php411 Spitfire Spitfire Clutch stopped Clutching Triumph 5
A Spitfire Spitfire Fan Clutch Triumph 8
R spitfire OD in MG midget, trany & clutch question Spridgets 4
J Spitfire Clutch Slave and master replacement , 78 Spitfire Triumph 13
G Spitfire mk1 mk2 spitfire clutch conversion ?'s Triumph 7
Simon TR4a Spitfire Spitfire clutch and swaybar Triumph 4
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
