REPLACEMENT WOOD DASH
starfall
HELLOW OUT THERE: I'M DOING SOME RESTORATION ON MY 73 GT6 & WOULD LIKE TO EITHER GET A NEW WOOD DASH OR HAVE THE OLD ONE REDONE. ANYONE HAVE ANY CONTACTS. THANKS STEVE.
Randy Keller at Prestige in Santa Ana Ca is really terrific on TR dashes and is a craftsman with custom wood.
Can the GT be redone as easily as the big 6's??
DNK said:
My ears are ringing! :devilgrin:
So are mine...
Steve, when you post in all capital letters, it is the equivalent of <span style="font-size: 20pt"><span style="font-weight: bold">SCREAMING!!</span></span> :devilgrin: :cheers:
Steve-Really not that hard to redo them your self
I made my own out of black walnut. I purchased a piece from a local lumberyard and had it milled to 3/8". I used the original dash as a template. By doing it yourself you can reposition guages. I added an oil pressure guage and an ammeter. One mistake I made was to have the board milled on the spot. Next time,I will let the wood dry for about 6 months before milling as it has a small (noticable only to me) curve in it.
Never really understood the cap lock issue....DO YOU READ IT LOUDER. Just sayin. BTW good luck with the dash Steve.
I think we scared him away.
Don't be shy Steve.
My first post were like that too.
Unfortune...for the boys here .....
I STAYED
beachbumbarry T-Series MG-TD wood replacement MG 9
J TR6 1975 TR6 Convertible Top Replacement. Triumph 1
wkilleffer MGB MGB windshield replacement near me MG 7
C TR4/4A Oil pan removal and replacement Triumph 27
C TR4/4A Install after jet gland replacement SU H6 in TR4 Triumph 9
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 25
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
WHT Rocker Arm Shaft Replacement Austin Healey 22
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
T TR2/3/3A Replacement radiators Triumph 8
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
F TR4/4A Replacement air filter for SU HS6 Triumph 6
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
A MGB MGB 1974 windscreen centre rod replacement MG 5
B Poor quality BE replacement spring boxes Spridgets 0
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
B TR6 Fuel tank replacement Triumph 0
S MGB clutch replacement MG 7
S Wiring Harness Replacement Spridgets 1
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
M 1972 Midget Seat Belt Replacement Spridgets 4
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
T TR2/3/3A tr3 front carpet replacement Triumph 5
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
D Engine replacement. Rover / Land Rover 0
EWD TR6 Dash Pad Replacement Triumph 3
R TR6 fan shroud replacement Triumph 5
C Replacement wheels Rover / Land Rover 1
B TR4/4A Floor pan replacement Triumph 4
DrEntropy MGB Replacement starter MG 7
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
M General MG Midget MK1 windshield replacement MG 2
M TR6 Replacement Steering Rack ? Triumph 7
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
A TR2/3/3A TR3-A replacement top Triumph 7
