Rear Disc Brake Conversion
sfovc2003
Has anyone had any success converting the rear drums on a BJ7 or BJ8 without too much fabrication? Any kits out there?
I have the Denis Welch ones with a Nissan B210 master cylinder. Since I have a BN4, I also replaced the front drums with DW's discs. The setup works great for driving, but I still am working on the parking brake.
Thinking outside the box a bit, I wonder if a Ford 8.8 from an Explorer would work under a Healey? https://www.therangerstation.com/tech_library/Explorer8_8.html They come with disc rears, traction lock diff and 3.55 gears. If it wasn't too heavy, I bet narrowing one, getting new axles and redrilling wire wheel hubs would be cheaper than trying to put new gears and disc brakes onto a Healey rear. And it's not like anyone is going to see it.
I have often thought of converting to rear disks but the expenditure is out of range for the amount of practical use. With the many versions of disk brake components installed on LCBs, I thought that someone would come up with the combination of commonly available elements that would fit and function on a Healey and be extremely inexpensive. But I guess, from a practical point of view, drums are perfectly acceptable after being balanced. Still, I like Rick’s initiative and wonder if there aren’t others that have found the Grail.
Ray (64BJ8P1)
Ray,
Looking at some online figures, the standard Healey rear end weighs 165 lbs (not sure whether that's with brakes). The Explorer 8.8 with brakes weighs 175 lbs. Sounds doable if someone was considering a 3.55 and disc brake swap for their Healey. I guess it would depend on how much the extra work to adapt wire wheel hubs and throw in the cost of a new driveshaft as well. One advantage to the Explorer is the parking brake issue would already have been worked out. Obviously, it's not for everyone, but if you're the type not offended by a Smitty's 5 spd, this wouldn't bother you too much.
I'd think that a 7.5" Diff from a mustang would be adequate. Again, plenty of gear ratios and LSD available with disc brakes.
I have the DW kit and it did require a good bit of fabrication. I do like the stopping power though. The parking brake is an issue as it does not work well or at all. The Jag guys say about the same thing on the XJ6's where the calipers come from. In retrospect I think I would investigate the cost to narrow a Ford rear end.
The standard set up in if properly maintained is really very good. For a car that weighs just over a ton 11.25" discs and 11" drums is a lot of braking power. Add improved pads and linings then what needs inproving? In addition the hand brake is really effective.
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
A AH 3000 rear disc brake conversion Austin Healey 28
S rear disc brake conversions brackets Triumph 9
M BJ7 Rear Disc Brake Setup Austin Healey 7
Fortius Dennis Welch Rear Disc Brake Conversion Kit Austin Healey 2
PAUL161 MGB MGB Rear Disc Brake Conversions MG 14
Jim_Gruber Creative Spridgets Rear Disc Kit Spridgets 11
T 'Creative Spridgets' rear disc conversion Spridgets 6
steveg Rear Disc Conversion Austin Healey 29
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
D Wedge Rear Disc Brakes for TR7 Triumph 16
Dave Richards Which Cars Had Rear Disc Brakes? Austin Healey 22
T TR6 tr6 rear disc brakes Triumph 30
R rear disc's MG 25
milemarker60 TR6 My Rear Disc Brakes on the TR6/M3 Triumph 0
GregW Factory rear disc kits? Austin Healey 28
Gearhead Rear disc brakes on a Midget Spridgets 2
69MGC Rear Disc Brakes MG 11
G MGB rear disc brakes for an MGB MG 5
5 Wanted Looking for a Rear Cockpit Molding for a BN2 Austin Healey Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
